Hardwood Underlay
I am installing 4" wide x 3/4" thick prefinished maple tongue and groove hardwood onto a plywood subfloor. I have zero humidity or moisture issues.
I wanted to use Aquabar B as my underlay, but it is not available in my area right now.
Other options are waxed paper, which I have used before with zero issues:
https://www.homedepot.ca/product/roberts-750-sq-ft-3-ft-x-250-ft-x-009-inch-waxed-paper-underlayment-for-wood-flooring/1000496301
Or I go with 15 lb roofing felt.
Any reason not to go with the paper? Should I wait two weeks to get Aquabar? I don't think I really need it.
Old 01-25-2021, 11:28 AM
Wax paper or visqueen will block vapor just fine but 15lb. felt is what I would use in liu of Aquabar though. No chance of a noisy floor.
Old 01-25-2021, 01:01 PM
I’ve used Kraft paper in a pinch.
Old 01-25-2021, 01:02 PM
I think I have a roll of roofing felt in the shed...I was also wondering about Tyvek.
Old 01-25-2021, 01:07 PM
You need something with a bit of "springiness," otherwise it will be very noisy (so no kraft paper or tyvek). Don't go with roofing felt as it will smell like tar.
You should look into a foam product from HD - I used the thin pink foam (cannot remember what its called) with self-adhesive strips along one edge...to lay engineered maple in my converted basement rooms.
Old 01-25-2021, 01:16 PM
I have never added anything 'springy' under a nailed hardwood floor. Only paper.
Old 01-25-2021, 01:30 PM
908/930's Avatar
Is the subfloor over non heated area? Over conditioned space I would do at least partial glue down, there is proper floor glue for this.
Old 01-25-2021, 01:45 PM
The floor is over a heated/cooled office in the house.
Instructions say nails every 9-10". That is how I did the last five floors.
Old 01-25-2021, 01:52 PM
Platinum Member
dad911's Avatar
15# felt, or rosin paper.
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk
Old 01-25-2021, 01:54 PM
Since this is a nail down use the felt. Any springy foam pad can lead to fastener noise eventually. And I don't use nails, I have cleat nailers using ribbed cleats. You can rent one and it's worth it on installation time saved alone. We use cleats because they will never squeak. A cleat every 9" minimum, 2" from all butt joints
Old 01-25-2021, 02:06 PM
I wondered about that too. Doesn't roofing felt smell like tar? Or does it dissipate quickly?
Old 01-25-2021, 02:24 PM
15 lb. felt will emit no odor. I've used it hundreds of times over the last 50 years as a vapor barrier. I only prefer Aquabar because it's lighter to handle and cheap. No need to overlap it either as you're just blocking vapor.
Old 01-25-2021, 02:29 PM
When I had my floor laid down, I used Tyvek and an underlayment. Mine is 3/4 in. X 1.5 in. quarter sawn oak done eleven years ago now. Maybe I was in error at the time using Tyvek, but I haven't had any problems with moisture, noise, or anything else since installation.
Marv Evans
'69 911E
Old 01-25-2021, 02:36 PM
Tyvek is a moisture barrier and would work just fine under hardwood. So would wax paper. Rosin paper would be pointless though. You probably wouldn't have a noise issue with any of the suggestions. I do this for a living and don't take any chances that's all. You need nothing at all if you live in the desert and have no moisture under your house.
Old 01-25-2021, 03:03 PM
The 9 Store
Tyvek is a water and air barrier but not a vapor barrier. Like Gore tex, it's designed to let vapor pass through.
All used parts sold as is.
Old 01-25-2021, 06:13 PM
Did not know that!
Forget Tyvek as a floor membrane then
Old 01-25-2021, 06:22 PM
Oh, great!
Marv Evans
'69 911E
Old 01-25-2021, 08:47 PM
^after 11 trouble free years I think you're fine
Old 01-25-2021, 08:50 PM
That was my thinking, thank you for the info.
Old 01-26-2021, 06:18 AM
It'll be legen-waitforit
stealthn's Avatar
You don’t want to use something that can retain moisture. We used a product from Schluter Systems, I forget what it’s called but they have a bunch of good stuff.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 01-26-2021, 06:19 AM
