Dang.. that ^ is an expensive record player needle. ;)
https://www.washingtonexaminer.com/policy/energy/how-and-why-a-nuclear-reactor-shut-down-in-texas-cold-snap-when-energy-was-needed-most " Many of the state’s gas plants were knocked out from icy conditions, and some plants shut down from being unable to access the fuel they need because producing wells froze. Wind turbines froze, too, but to a lesser extent." |
1. the reason you dont have straight runners is you need to actuate the valve, either a cam or rocker will be there. even in a cam-free engine, you still have the linear motor for the valve that needs to be there. 2. rotary valves would not solve the problem, as you still need something to spin them, and they will because of the need to spin, use ~50% less area than a standard poppet valve. file this one under "no, you arnt smarter than ~100 years of engine designing engineers" |
so, its the natural gas that is failing them, not wind or solar. solar actually works better in the cold. a serious problem in solar power is actually the cells getting too hot. the cells themselves are actually more efficient in the cold. the issue in the winter time is that there is simply less solar power available, due to, you know, the angle of the earth. snow/cold does not render solar cells ineffective, and texas doesn't have many anyway. its privatization of the grid, and optimizing there power system for profit that has them without power. not solar and wind power. |
And the ones that could run, some of the gas compressors were shut down by the local utilities during the rolling blackouts, making things worse. Ice build up in a cooling tower is definitely not normal for south Texas. North Texas did far better, since they regularly go below 32F/0C in winter, for extended periods of time. |
| All times are GMT -8. The time now is 09:10 AM. |
