-   -   Boxter Radio question (http://forums.pelicanparts.com/off-topic-discussions/1087308-boxter-radio-question.html)
PorscheGAL 03-01-2021 07:14 AM
I tried to post this in the Boxter forum but after 150 views, I have no responses. I know there are quite a few people in OT who might have an answer or narrow down where to look that never go to the Boxter forum so I thought I would try.
A friend just purchased a 2000 Boxter. He is saying he has a CDR220 radio that holds 1 CD at a time. He pushed the eject button, nothing came out and he inserted his own CD. When he puts it on CD, it is not playing his CD but something completely different. I have not seen the car but will probably run over there tomorrow to look at it. He says there is no multi-CD box in the trunk. I asked him if it is possible there is a aftermarket CD player under the seat? Any suggestions on where to look for this mysterious CD or audio source?
Thanks guys.
RANDY P 03-01-2021 07:31 AM
If eject isn't working there's likely a CD stuck inside and it won't come out. Seen that before with auto CD players.
HardDrive 03-01-2021 08:36 AM
Hurting my brain trying to remember. I swear the CD player is hidden behind a panel in the trunk.
KFC911 03-01-2021 08:37 AM
Another CD would not insert if that were the case. There's gotta be another input... under a seat, etc.
masraum 03-01-2021 08:44 AM
Right, I'm not sure about a 986, but I do believe the 987 has it "hidden" in a box behind a panel in the frunk.
masraum 03-01-2021 08:45 AM
I do know that some automotive CD players could have multiple (usually up to 3) CDs inserted through a slot at the same time, but I didn't think the CDR220 had that capability. Maybe it does/did in the 986?
KFC911 03-01-2021 09:38 AM
^^^ I just learned something new, but there's a multi-disc player hidden somewhere ;).
pwd72s 03-01-2021 11:59 AM
Pretty common problem with the '08-09 Bullitt Mustang...jammed CD player with the factory stereo. Most common solution is aftermarket stereo. Ford bean counters at work.
Mine's never jammed..only used it once. After reading if the problem I use an ipod set to shuffle play..
Nostril Cheese 03-01-2021 12:20 PM
CD Changer should be located in the front trunk near the spare.
Try pressing the eject button with all power off for 5 seconds. If it doesnt eject, turn the ignition on while still holding the button. This has worked for me in the past...
Nostril Cheese 03-01-2021 12:23 PM
Try jamming a pool cue in the CD slot.
pwd72s 03-01-2021 12:28 PM
Too easy...so I won't post it...
PorscheGAL 03-01-2021 12:35 PM
Thanks for all the suggestions. I really appreciate it
masraum 03-01-2021 12:46 PM
Originally Posted by nostril cheese (Post 11244261)
try jamming a pool cue in the cd slot.
roflmao
Jeff Hail 03-01-2021 02:23 PM
Interior behind seat, below the back window in the dope compartment.
rusnak 03-03-2021 01:31 PM
Probably a 3-disc changer in the glove box.
onewhippedpuppy 03-03-2021 05:45 PM
Yup, all of the 9X6 models have it there. I bet it’s picking up the changer.
Nostril Cheese 03-04-2021 01:57 AM
Originally Posted by masraum (Post 11244301)
roflmao
its gotta be a fetish
http://forums.pelicanparts.com/uploa...1614851825.jpg
pwd72s 03-04-2021 12:16 PM
Zero desire for a Mustang table, but sure would take this:
http://forums.pelicanparts.com/uploa...1614888934.jpg
maxnine11 03-05-2021 04:22 PM
Is there possibly an iPod or mp3 player hooked into the aux in port of the head unit? (The same port that would be used by an aux cd changer)
The optional CD changer mounts near the spare tire.
Should be fairly obvious.
https://motorwerke.ca/wp-content/upl...-Repair-30.jpg
