On the beater it has been on for about 120K miles. I can't remember exactly what for, heated 02 or bad cat, something in that department. I don't give a rip and I'm sales rep for a company that sells both. I wear 2 hats when it comes to that light. No emission testing here.
I owned a 2003 VW Passat for 5 years - bought used and put 50K mikes on the car. The check engine light was on more than it was off. All emission related issues.
I was working in Mexico for a few weeks during this time period and most of the taxis were VWs. Every taxi I was in had the check engine light on. Must be common i said to myself. |
In response to the OP, no it would drive me bonkers. I'd have to eliminate the problem asap. <iframe width="560" height="315" src="https://www.youtube.com/embed/5WnM_NsOtd8" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
I understand that I am weird, but every system, control or feature on my cars, work as designed from the factory, or even better. |
Instead of a cel they should use the $ as the indicator of how expensive it will be to fix, from: $ to $$$$$
Had a 99 VW TDI. Took it to the dealer because the check engine light was on. Still under warranty it was. They kept it for a day and as I was driving it away the light came back on again. Had to leave it another day. That car would throw a CEL every week. Never another VW.
Can't pass NJ inspection if check engine light is on. Junked a running VW Jetta because of that. New cats were more than it was worth.
I know people that also think the oil light means add oil, or get it changed. |
Our car currently has the CEL. It is because it doesn't warm up fast enough so I have to change the thermostat.
In my subie, I will worry when it shuts off. The jeep I expect to work as advertised day in day out so it I would have rectified.
But in the end, a CEL is never really a panic. Should be checked so you know why it popped, but even the lean codes pop to tell you that the car has experienced a lean bank and is needing to exceed the fuel schedule to correct it. A car smart enough to tell you it is lean is smart enough to correct it almost every time. The biggest impact to almost any CEL fault is most likely a small dip in mileage. |
^^^ Correct. There are other lights on the dash that are a lot more important to react to.
It's partly why I like my '87 911 better than my '90. Soon after I bought my 964, some rubber air shroud/duct just above the fan in the engine compartment disintegrated. Or rather popped while I was driving, as it's slightly positively pressured, I think. Somehow that set off the knock sensor, which tripped the CEL. Even after I replaced the part, the CEL remained lit. I had to get the CEL extinguished at my mechanic (thanks, TRE) because I don't have the Durametric to do that. |
Most folks have some vehicles that are nothing more than an appliance to them, and are mostly considered consumable and disposable. Also, I wouldn't want to spend a ton of money to keep an econobox that's probably half plastic and engineered to be disposable in perfect shape. Many of us probably maintain some cars to a higher standard, but not all of them. Part of the deal is maybe that you've got great cars that are worth maintaining? |
The check engine light on my 2003 Tacoma was on for so long ( 5-6 years i'm guessing) that the bulb finally burned out.
Inspections?? In MI...if you have the money for the plate...you are good to go.:D
| All times are GMT -8. The time now is 11:09 PM. |
