-   -   I need help finding replacement cabinet hinge (http://forums.pelicanparts.com/off-topic-discussions/1088399-i-need-help-finding-replacement-cabinet-hinge.html)
Rot 911 03-13-2021 06:45 PM
This is the hinge for an inside corner cabinet that opens up to a Lazy Susan in our kitchen. The problem is the locking tab on the inside is broken off. I don’t even know where to start looking for a replacement hinge. Any ideas? If I can’t find a replacement hinge I’ll just rig up some kind of MacGyver fix. Thanks!
http://forums.pelicanparts.com/uploa...1615689824.jpg
look 171 03-13-2021 09:17 PM
That should be a 45degree hinge? Show me a pic of the corner
That looks like an Chinese import? There's should be a stamp inside the cup somewhere on the hinge. Its not a 110 or 120 degree.
pwd72s 03-13-2021 09:27 PM
Any cabinet shops in Lincoln? One might have a replacement sitting in parts..
look 171 03-13-2021 09:39 PM
That's a very specific hinge for the angle of his corner cabinet. Depending on the brand, the plate, the broken part can't be purchased by itself.
VINMAN 03-13-2021 10:08 PM
I might have one. I'll check for ya.
dad911 03-13-2021 10:26 PM
https://www.cabinetparts.com/g/angled-european-cabinet-hinges-g14437
Pic of cabinet and we can narrow it down.
Home depot also has some in stock, you may be able to match it up. Basically need to know frame or frameless, angle of opening, and offsets.
john70t 03-13-2021 10:30 PM
Take off the other good one and measure the specs such as full open rotation sweep etc.
(I don't remember the technical names for those)
It looks very similar to a Grass hinge I once replaced. Same location. It was a pain to find.
Take photos with measuring tape.
If you can't match it with the cheapo box store garbage which I wouldn't recommend, or a local cabinet store, they might be able to.
It was something like $20-30 from another website like cabinetparts but it got fixed.
I also had to install additional brackets inside to keep the cabinet carcass panels from moving.
Both hinges.were replaced.
Adjusting takes a little time to figure out but it's nice when it's close to perfect.
gregpark 03-14-2021 01:00 AM
https://www.rockler.com/blum-170-deg-pie-corner-hinge-kit-frameless-inset
Bob Kontak 03-14-2021 05:25 AM
Habitat for Humanity - you have two in Lincoln.
I've gotten lucky there before.
cabmandone 03-14-2021 05:31 AM
Amerock
I have the same hinge on my lazy non gender specific name cabinet :)
https://www.shopamerock.com/Amerock/European-Hinges/amebp4613d14-ms.html;jsessionid=BACD2E457FEC7462568BED04958E33E 6.worker2?gclid=CjwKCAiAhbeCBhBcEiwAkv2cYxdk69oBhf jS_BVjxhXvXjzQ6hh6nZs7MwYynsUUuo-pahh2lq_NJhoCp-AQAvD_BwE
Biggest issue you might have is that the holes on the new one won't match the old. I had to take my doors to my friend and have him put it in the machine that bores the holes. But I think I also went with a different brand because it was what my friend had in stock.
cabmandone 03-14-2021 05:45 AM
Is that the hinge that goes from the cabinet rail to the door itself or is that the hinge on a two piece corner door that joins the two pieces?
Rot 911 03-14-2021 07:14 AM
Nick wins the prize! That’s the hinge! I told my wife that if I post it on the pelican board someone would be able to help us out. And thanks to everyone that weighed in on this first world problem!
look 171 03-14-2021 09:54 AM
The cup and holes will always fit because those cabinets are built based on a 32 mm system. That means the screw holes are always 32 mm apart. The hinge cups are always 35 mm. May I suggest you buy a set of Blum, I know, they are more money, but worth the paying extra. The clip together instead of sliding into a slot and held together by a screw between the hinge and plate. That Amerock maybe the wrong hinge? Its 1 1/2" for 1 1/2" overlay doors. Notice the hinge cup is above the plate fully open, your hinge is when open fully.
I am bias because I have all the Blum drilling equip at our shop and I know they made a great product. Many of their products are still made in Austria.
Get me a pic
cabmandone 03-14-2021 11:57 AM
Lucky for you mine broke several years ago! And even more lucky I remembered the name of the manufacturer! Glad I could help.
cabmandone 03-14-2021 12:01 PM
That has not been my experience. I have 4 screw holes in several doors because the newer ones have a hole that is either forward of or behind the old original set. I don't recall which it is. Spacing side to side is correct but front to back... not so much
Rot 911 03-14-2021 02:23 PM
I’m pretty sure the one pictured in the link is the same one I have. One of the pictures has all the dimensions and it matches up with my broken hinge. Keeping my fingers crossed!
cabmandone 03-14-2021 04:12 PM
My friend doesn't use Amerock anymore so my new hinges weren't a direct replacement. I think you'll be okay.
look 171 03-14-2021 07:15 PM
They must have just rammed that screw in there without carefully measuring. That hole should be 5 mm, made for plastic dowel insert. If its just a screw hole, then they don't have the right equip and measured it out by hand. Doing it that way is very inconstant. Come installation in the field, they will ram new holes to adjust for fit causing everything to bind.
If you are talking about hing plate placement (on cabinet side), that's a very specific dimension, exactly 37MM from front finish edge of cabinet. From the edge of the cabinet door to the edge of hinge cup is normally 3 mm to within a 1/2MM. That will cause the door to bind depending on the size of the door that's cut. We use an Inserta hinge by Blum. The cup expands into the surrounding materials. Once its expands, its on tight. That or Plastic dowels with screw insert using a Blum machine pneumatic ram for that only purpose. They seem to be best IMO. It will tear out chunks of plywood before the plastic dowel fails. I have done testing with a sledge long ago.
Good luck. Replace both hinges and plate at the same time.
Gogar 03-14-2021 07:40 PM
yep that's just a run-o-the mill blum
