-   -   Can anyone help ID these things? (http://forums.pelicanparts.com/off-topic-discussions/1090113-can-anyone-help-id-these-things.html)
Baz 04-03-2021 10:46 AM
I don't think they are rivets.
I have a half a small peanut can of them.
TIA!
http://forums.pelicanparts.com/uploa...1617471953.JPG
Zeke 04-03-2021 11:18 AM
Yeah, it's a 1987 US Penny.
Nostril Cheese 04-03-2021 11:43 AM
They look like parts to a air hammer. A really SMALL air hammer
id10t 04-03-2021 12:14 PM
The threaded spikey thing looks a lot like the optional spike feet that came with my Caldwell front rest
herr_oberst 04-03-2021 12:27 PM
floor speaker spikes?
oldE 04-03-2021 02:00 PM
Perhaps spikes for a tripod?
The threads would provide adjustment.
Just guessing.
Best
Les
flatbutt 04-03-2021 02:10 PM
A masonry anchor?
cabmandone 04-03-2021 02:30 PM
The thing on the bottom right is a 1987 penny. :)
Baz
If you don't mind me asking, how do you end up with half a small peanut can of stuff and you don't know what it is?
stevej37 04-03-2021 02:31 PM
anchors for tooth implants
dad911 04-03-2021 02:36 PM
Looks like some sort of anchor, like a manual version of this:
https://images-na.ssl-images-amazon....mKCYL._AC_.jpg
If you drove the pin into something, would the washer move on the shaft?
KFC911 04-03-2021 02:40 PM
Originally Posted by cabmando (Post 11283807)
Baz
He found it on the side of the road .... just too good of a deal to pass up :D
rusnak 04-03-2021 02:46 PM
They are galavanized, so probably meant to go outdoors. Maybe fence hardware, or fasteners for metal siding, like on a barn or something.
Baz 04-03-2021 03:26 PM
Either from my late stepfather's accumulation of fasteners or from a collection I purchased from a friend who was liquidating her late father's stuff. The second collection included a metal cabinet with drawers filled with all kinds of fasteners. I'm sorting through some of this stuff and always wondered what these things were.
No moveable washer - all one piece, but appreciate the help.
Originally Posted by rusnak (Post 11283828)
They are galvanized, so probably meant to go outdoors. Maybe fence hardware, or fasteners for metal siding, like on a barn or something.
This is what I was first thinking - something to do with fencing because of the little wire loops. But it could be something else meant for outdoors. I just don't have a clue what though.....
Thanks for the laughs and guesses so far. I don't feel so bad now not knowing what these are.......;)
rfuerst911sc 04-03-2021 04:13 PM
Pretty sure they go in your nipples ............ go ahead and jamb the pointy ends in and let us know how you like the look :D The knarly S hooks are for your partner to hang onto .......... maybe you can use a fishing lure to spice things up :eek:
flatbutt 04-03-2021 04:16 PM
https://youtu.be/5rKmCLRBLHQ?t=427
TimT 04-03-2021 04:36 PM
https://www.mcmaster.com/mvB/Content...=ImageNotFound
Looks almost like this
McMaster
The pointy things look like some sort of turning center/transfer not sure
Baz 04-04-2021 11:29 AM
Originally Posted by flatbutt (Post 11283784)
A masonry anchor?
Looks like some sort of anchor, -snip-
Sent the pic off to my oldest brother who is a machinist and metal fabricator.
He said some kind of drive anchor.
Said the little curly things were some kind of 90 degree clasp someone came up with.
I will update the thread as I discover more info.....
rcooled 04-04-2021 12:45 PM
Don't know about the bent wire things, but both the threaded piece and pin with sharp points might be devices used to transfer hole locations from one work piece to another. I used something similar to line up thru holes for screws with their threaded counterparts on a removable panel for a cabinet. Screw or press the pin into a hole in one piece, then when you bring the two pieces together, a witness mark for a mating hole is left by the sharp point.
varmint 04-04-2021 01:45 PM
don't know what they're called. but my dremel tool came with a bunch of them.
Zeke 04-04-2021 02:33 PM
IDT the links and the pins are related.
The hooks look like something from an old style overhead garage door spring. I've seen those someplace and I've been thinking about it since yesterday.
And the more I look at the pins the more I see a masonry drive anchor. The washer moves up as it is driven to depth. Probably powder actuated type tool.
