Any tips on motorboating a lower unit ?
I really want to stop , but I cant
I'd recommend that you stick with inboard.
Unless you really want to go outboard, not that there's anything wrong with that, if it's "your thing." And these days, you've got to confirm that you don't go inboard-outboard. Let's not add any confusion to the mix. |
Anyone have a bookmark to PoP's "Slap that cratch" ?
Motorboating can work on upper or lower units.
nacho cheese labia, yo
They need to be rinsed between put-ins...zebra mussels and all.
Gotsta pass the sniff test first.
At least you guys are jovial, due to the friggen ice and snow storm, my beautiful Chris Craft engine block is cracked. Im in Texas and we never get cold, block is cracked and now the yacht is a row boat..:(http://forums.pelicanparts.com/uploa...1617900717.jpg
^^^ what engine do you have? Also depending on where the crack is assuming you have raw water cooling, you could wind up sinking it.
My brother bought an insurance write off with a 305 in it last year and rebuilt it. He then decided he wanted more power and bought a 1997 350 out of a Tahoe and built it up to about 400HP. It’s a pretty inexpensive engine to rebuild. Engines are not too expensive and if you get a late model engine, really all you need to do is put in the windage tray and oil pan, a marine cam, bronze frost plugs. You will probably want to run your heads and manifold. You should run your marine carb as well as they are set up differently than an automotive carb (this is important for liability reasons).
You can fix this for under $1000 if you can do the work yourself. |
On a lot of boats,certainly my cabin cruiser with hardtop wheelhouse, getting the engine out is the biggest problem. All sorts of work needed to the interior, and roof removal, just to get access for the engine crane.
There will be 4 frost plugs (2 on each side) and I think 2 in the bell housing of that engine.
Also check your exhaust manifolds. They are likely cracked too. This is pretty common on non winterized boats here. |
Saw one block last week that was cracked at the mating surface for the heads, inside surface. It was pretty bad. The freeze plugs were somewhat pushed out, but not enough to save it. 350, Lake Travis. Lots of boats in Texas out there with cracked blocks.
| All times are GMT -8. The time now is 05:47 PM. |
