-   -   Clutch question (http://forums.pelicanparts.com/off-topic-discussions/1093443-clutch-question.html)
Bugsinrugs 05-14-2021 04:04 PM
Clutch question
My son had a new clutch, pressure plate, flywheel, pilot bearing and throw out bearing installed on his 01 Tacoma. He says he has a squeel but if he barely touches the clutch pedal it goes away. I’m thinking maybe the throw out bearing needs to break in. Anyone had this issue?
Nostril Cheese 05-14-2021 05:46 PM
Somethings not right with the throw out bearing. SHouldnt need to be broken in
Bugsinrugs 05-14-2021 05:54 PM
That’s what I was dreading
Nostril Cheese 05-14-2021 05:56 PM
Try revving the engine in neutral without pushing the clutch. Does the noise change?
Tobra 05-14-2021 06:28 PM
He needs to take it back to the shop
Bugsinrugs 05-14-2021 07:19 PM
I called the shop and they said bring it back.
asphaltgambler 05-15-2021 06:18 AM
Either the pressure plate springs are uneven causing side loading of the T/O bearing, or the bearing is defective
