Question: Copper Pipe Threads vs Brass (Same?)
I'm wondering if the threads on copper pipe fittings are the same as brass.
I'm asking because I'm plumbing for my new Tankless Water Heater and the unit came with a brass fittings kit (i.e., parts that have valves and connect to household plumbing). I purchased 3/4" male threaded fittings that will be soldered to the copper input/output piping but they don't screw into the brass fittings very easily and start resisting after about 1-1.5 turns. Seeming like it's not a match, I tried threading in a 3/4" brass fitting and it went in fairly easily and started resisting after 5+ turns. Anyone have experience with this? I'm wondering if I should be using a brass fitting with a sweat to copper connection? I can't find the installation manual for this and having trouble locating on net. |
Not sure, with copper vs brass do you need a di-electric union?
Yep.. NPT.
If you're worried, take one of your fittings to a box store and give it a try. It's possible the fitting you bought has bad threads. Wouldn't be the first time I've had that happen. |
Just be sure you don't mix parallel threads (hose bib) with NPT. NPT requires tape and/or goop to not leak. There are some hose assemblies with fittings that have parallel threads but they are meant to attach to NPT. Those have seals to make it work. I think I have that correct. ?
I didn't answer your question. The NPT slip fittings NPT threads will match up with brass items with NPT threads.
I've been looking at internet photos and I see both brass & copper being used for the final connection to the water heater. Regardless, I am going to bring my connection fitting with me and make sure I get the correct final pipe connection before installing. |
What a re you trying to do?
I used the kit for my tankless, makes it easy to flush.
https://smile.amazon.com/Rheem-RTG20220AB-Webstone-Tankless-Service/dp/B00C5YBENQ/ref=sr_1_3?dchild=1&keywords=Webstone+3%2F4+in+Bra ss+Tankless+Water+Heater+Service+Valve&qid=1621467 875&sr=8-3 Are you going to copper or pex? If copper I'd use the water heater supply flexible lines with sharkbite ends. |
So now I have run copper up the wall and out to where it will eventually connect to the tankless but the ends of the copper have to be threaded and will thread into the brass coupler connection kit that ultimately hooks to the tankless. Everything was going smoothly until I test threaded my fittings into the brass kit and they don't screw in very well and I was afraid I would strip the copper. The copper fitting will screw in 1/2 turn and then stiff where as a galvanized pipe will screw in 5 full turns before getting stiff. This is a photo of a similar install valve where my copper line will connect at the bottom and the top connects to the tankless via a coupler. http://forums.pelicanparts.com/uploa...1621476728.jpg |
you need this lil' guy https://www.lowes.com/pd/NIBCO-3-4-in-Copper-Threaded-Adapter-Fittings/3505128
Large pic of the connector at my home. Just shot that pic for ya, Vern.http://forums.pelicanparts.com/uploa...1621478167.JPG
http://forums.pelicanparts.com/uploa...1621478167.JPG |
That was installed over 10 years ago. There's a thermo switch that's attached to the hot returning water line. Once it drops below a certain temp, especially in the winter months, it will kick on the pump. Since it doesn't get that cold here, it will runs for about 20 seconds, about 15 times per hour. I had a timer hooked up to it, but removed it because I realized it was running so little during the night. I pulled it to keep having too much crap there.
A return pipe is needed from various locations or the furthest point from the heater. Check valves are needed to keep water from entering back into pipes where you need to keep hot water out. Check valves do go bad over time due to hard water. |
It has the ingredients of both metals but it doesn't self-corrode which is kind of interesting. Some pipe foam insulation sleeves and a WH blanket will help keep in the heat. |
| All times are GMT -8. The time now is 07:52 PM. |
