The structural engineer will need to sign off on this before the building inspector will approve anything.
If you are really thinking about cutting out the bottom sides and doing doggy doors to cover it, make sure the open doors themselves clear 54 inches at the bottom, or you will need to slot those as well. |
I also thought maybe a one sided ramp would be enough. Of course, I would need the opposite on the the other side of the door.
What's a building inspector?? :D I built my 12X20 deck...added on to it twice....building inspector never came out. |
Actually, with the AWS you should be able to boogie the tractor right in (somehow)... |
^^^ I'm wondering that also, after yours and masraums post.
Sure would make it easier. |
Someday you'll figure out that a zero turn is the way to go!
This is what you need https://www.deere.com/assets/images/...db17fecd85.jpg |
Same width....won't fit in my building. |
You could buy a 48" Z and still mow faster than the traditional rider even with AWS.
I know... I know... "It's not how fast you mow but how well you mow fast". That's what people with slow mowers say. And let's not get into my deck is bigger than yours :-) |
^^^ a friend of mine has one of those (grasshopper)...he likes it. I asked him about the under-deck cleaning and he said it was ok..but not very good.
I'm still not sure...looking. |
BTW on your doors is the current opening, not the doors, 60"? It looks like maintaining the current height and making the opening wider would get difficult because of the gambrel roofline.
Only drawback to the front runner style mower is the rear wheels and getting a feel for where they are when you're turning near your house or outbuilding. Easy to bump stuff. |
Don't get the cart in front of the horse. Get your mower and see what needs to be modified afterwards (if anything).
Best way to keep from having to scrape the bottom of the deck is to not mow when the grass is damp. That and put some slip plate on the bottom of the deck
^^^ yes...the opening is 60 inches. That's my worry...widening the opening is going to eliminate some of the structure support.
| All times are GMT -8. The time now is 10:24 AM. |
