Stove top hood controls
Raining all weekend so it's project-palooza. The touchless controls for my stove hood were going wonky so I ordered a new control set. What they sent didn't work so I took the button box apart and cleaned it (lot of oil) and it started working. But not working.
Control box not mounted, held in your hand Springs work fine Button plate works fine. In fact button plate you can get your finger close but doesn't touch a button and it actuates on and off Box mounted, that is held in place in the hood Springs (no button plate) don't work Buttons don't work Box just touching the hood, nothing works It's a plastic box. Any ideas? Seems very odd. New controls on top, old with separate button plate below. No idea what the circuit board is for, I don't have one. http://forums.pelicanparts.com/uploa...1622317346.jpg Holding my old control box. Only springs. Works fine. http://forums.pelicanparts.com/uploa...1622317346.jpg With the plate, works fine http://forums.pelicanparts.com/uploa...1622317346.jpg Held in place in hood. No button plate. Doesn't work. I started the fan at level 1 before holding it up. http://forums.pelicanparts.com/uploa...1622317346.jpg Just holding the box against the underside of the hood. Doesn't work. http://forums.pelicanparts.com/uploa...1622317346.jpg |
Some kind of magnet or electrical interference caused by being near the hood?
I have a fridge in the garage that leaks enough current that it zings you if you're in bare feet on the concrete. The grounding circuit in my garage is deficient. (Working on it installing a new sub panel and separate ground rod.) |
Good question Milt, I am assuming it isn't. I'll check later today. The controls have worked for 10 years or so.
The hood itself is just mounted to the wall. There's no ground from the hood to a building ground. The fan is a standard plug that is in a floating outlet i the rafters that is bridging the wire from the breaker box to a wall out next to the stove. it's 3 wire grounded of course.
get rid of it and re-purpose some old flip switches from a Jag
When electronics work by touching or holding them it is typically a capacitance issue.
Your body is acting as a capacitor. |
| All times are GMT -8. The time now is 11:05 AM. |
