-   -   AC Compressor - Dead? (http://forums.pelicanparts.com/off-topic-discussions/1095205-ac-compressor-dead.html)
1990C4S 06-07-2021 08:33 AM
My son's '02 Jetta AC compressor is engaging and not grinding/making terrible noises. But no cold air.
Low and high pressures are correct when resting, 100-110 psi both sides.
With AC on I see liquid bubbling in the bottom third of the glass on my gauges, but the pressures barely change.
I'm guessing the compressor has died?
hcoles 06-07-2021 08:42 AM
I suggest if your AC compressor is making any sort of "bad" noise is to stop turning it (AC off).
You might avoid blowing chunks throughout the system.
1990C4S 06-07-2021 08:45 AM
There is no bad noise. It is quiet.
A couple of possible scenarios, clutch is engaged but slipping?
Still low on freon, although 100 psi resting would indicate not.
Compressor seals are gone internally.
rusnak 06-07-2021 08:53 AM
If low and high pressures are the same, then it sounds as if the expansion valve is clogged. It also sounds as if you are low on charge.
1990C4S 06-07-2021 08:56 AM
Is 100 psi low? I was thinking that was about right...but I could easily be wrong.
At this point on the old car I could just add some more...
asphaltgambler 06-07-2021 11:52 AM
What is the low/ high side readings @900 RPM's?
1990C4S 06-07-2021 11:55 AM
^^^^ Roughly 100 psi on high and low when idling, low starts to drop a bit, then goes right back to 100 ish.
asphaltgambler 06-07-2021 11:58 AM
So it seems the compressor/ internal valving has failed. It's not generating pressure or suction at all.
JackDidley 06-07-2021 12:02 PM
I think the low side should be around 40 at idle. Low and high should not be near the same.
1990C4S 06-07-2021 12:04 PM
Seems that way...I guess it's toast.
1990C4S 06-07-2021 12:05 PM
That should be at idle, but when compressing they should be more like 40 psi low and 150-250 high...
JackDidley 06-07-2021 12:09 PM
Yes, you seem to have equalized. Probably time for a compressor.
asphaltgambler 06-07-2021 12:31 PM
I would safely rule out anything else in the system as nothing is going on with the low / high side
mattdavis11 06-07-2021 12:39 PM
Check the air gap at the compressor clutch, if too great, remove the outer hub, remove shim in hub, or on shaft(if needed). The air gap should be about the thickness of a business card.
However, my bet is on refrigerant control valve on the back of the compressor. Same pressure = Equilibrium. Looks just the same as a stuck open expansion valve. Most of the time you see expansion valves pull the low into a vacuum when bad. I've only seen a couple go the other way.
Refrigerant control valve.
1990C4S 06-07-2021 12:41 PM
Yea, I was wondering about the clutch not really engaging. I think I will get down and feel the compressor. If it's rotating inside I should be able to feel it.
mattdavis11 06-07-2021 12:58 PM
What size motor? Diesel? Gas? Gl? Hard to ID the Sanden compressor with out more info.
mattdavis11 06-07-2021 01:04 PM
If the valve, (if it has one) is sticking open, you may not. Rotate the hub, see what it does. It will feel like a somewhat like free spinner if it has a valve, and want to pound low pressure vapor into a high pressure vapor if no refrigerant control valve.
vash 06-07-2021 01:06 PM
when my compressor quit, or so I thought; it was more of an electrical problem. I was checking fuses, relays and grounds. I changed a few things and it all got cold again. think this is an option?
1990C4S 06-07-2021 01:15 PM
2.0T, but it's the same compressor as my TDI. It's the cheap on/off style. VW also has a climate control variable compressor.
mattdavis11 06-07-2021 01:17 PM
Maybe. Not likely though as the compressor does engage.
