-   -   Best battery powered tools? (http://forums.pelicanparts.com/off-topic-discussions/1096023-best-battery-powered-tools.html)
dennis in se pa 06-18-2021 03:34 AM
Anyone have a recommendation for good battery powered yard tools?
PorscheGAL 06-18-2021 03:38 AM
Ego makes a great lawn mower and string trimmer
Batteries last for a yard about 10-12K square feet. String trimmer is easy to load.
hbueno 06-18-2021 04:43 AM
Seconding EGo. i have the string trimmer and hedge trimmer. Very powerful and batteries last long enough to get the work done
Rusty Heap 06-18-2021 05:24 AM
Dewalt makes powerful weed eaters and leaf blowers too. 20 volt or 60 volt.
cabmandone 06-18-2021 07:02 AM
My Son just bought a Hart leaf blower from Walmart. The thing is extremely powerful and priced reasonably. I find myself grabbing it to clean the barn floor or get the stones off the concrete approach rather than my Husqvarna backpack blower.
https://www.walmart.com/ip/HART-40-Volt-Cordless-Turbo-Fan-Blower-Kit-1-4-0Ah-Lithium-Ion-Battery/859170729?wmlspartner=wlpa&selectedSellerId=101065 712&&adid=22222222227329311268&wl0=&wl1=g&wl2=c&wl 3=412278576368&wl4=pla-861216178479&wl5=9015981&wl6=&wl7=&wl8=&wl9=pla&wl 10=377890897&wl11=online&wl12=859170729&veh=sem&gc lid=CjwKCAjwiLGGBhAqEiwAgq3q_pEMDFrM5CeuaSaya7B6Nm fPgAI2mnx-6IjxFxSWGKBgOYvueKqvIRoCw0wQAvD_BwE&gclsrc=aw.ds
aschen 06-18-2021 08:19 AM
had ego stuff for a few years and have been more than satisfied.
The speed control on my weedeater has gotten a little wonkey in the last year. Full speed and half speed work fine but I have lost fine control. I have had it for 3 years still works well enough. Mower has been flawless for 2 years as have the batterie. I can mow my yard 2times on a single charge of the 7.5 AH battery. yard is small, 9000 sqft lot but in houston it turns into a jungle between mowing.
As I have said a few times, I will never go back to gas yard tools unless I move to multiple acres and then still probably not.
1990C4S 06-18-2021 08:24 AM
I find Ryobi to be good value. I'm sure you can spend more and get better, but they have served me well.
vash 06-18-2021 09:30 AM
i need one. i have gotten into the habit of blowing out my garage with my leaf blower. its so fast. takes more time to start my POS Husky blower.
gtc 06-18-2021 01:36 PM
I would not recommend Ryobi. In my experience, about the only good thing about them is that they are among the least expensive.
We have a Ryobi 18v leaf blower. It works ok for small stuff, but can't really handle the big leaf maple in our back yard. The original battery had some sort of internal fault and will no longer charge.
I tried one of their chain saws, but the motor overheated and tripped a thermal switch on the first use. There was no external breaker for it, and it didn't reset after cooling down, so i returned it. I would be wary even under light use, though, because the tensioner was fussy and the oiler didn't dispense enough oil.
flatbutt 06-18-2021 01:44 PM
Is Ego a Lowes exclusive?
flipper35 06-18-2021 02:20 PM
We have a B&D trimmer of the old 18v variety that just died after 14 years. I think it is a brush in the motor, but it has served use well and was probably undersized for how we used it. Got a new 20v 2 speed and will see how that goes. Dad has a similar one to our old one and gave him the 5000mAH batteries. On of those will do his yard 3 times before it needs charged again where it would do about 2/3 our trimming needs befor ewe got a gas trimmer to supplement. I don't like using the gas against the play set or fruit trees so the kids use electric on those.
We have a Greenworks leaf blower. It was the most cfm and wind speed for the least money. Haven't had to use it yet but it seems to blow very well in testing.
Seahawk 06-18-2021 02:38 PM
I won't either. When we sell the farm, and I take really good care of all the Stihl stuff I own (my 27 year-old Stihl trimmer starts like a Camry) , I'll never own a gas powered anything again for the yard. Chainsaw may be the only exception.
They have electric powered ZT mower, FTW!
BTW, I do Ego as well. One blower so far, very satisfied.
masraum 06-18-2021 02:51 PM
Interesting. I have Ryobi blower and string trimmer. They both seem to have enough power and battery life for what I need/use. I don't need much out of either, but if I did, I have 3 batteries, so I could swap batteries. The only problem that I see with an electric ZT is that once the batteries are dead, you've got to wait until they recharge to use it again. I assume you won't be unplugging a battery pack and then plug in a spare. Of course, maybe the battery life is enough for that to not be an issue. I don't know.
Seahawk 06-18-2021 03:31 PM
I have done zero (turn) homework other than watching the commercials. When I move, I’ll get serious.
I have moved as much to batteries as I can.
Bill Verburg 06-18-2021 03:40 PM
Ryobi 40v
I have a 10yr old string trimmer
a 3yr old string trimmer
chain saw
horizontal disk edger attachment for the newer trimmer(bottom attachments are interchangeable)
vertical edger disk attachment
backpack blower
2 hand held blowers, the newer 525cfm is the nuts but they have an even more powerful 730cfm version that beats the back pack
also 1/2 dozen 4 to 6 amp hr batteries
KevinTodd 06-18-2021 03:59 PM
I have an Ego leaf blower and it outperformed my Echo gas powered one by a long shot. Really impressive power as well as battery life.
masraum 07-03-2021 04:05 PM
I'd used my Ryobi 18V string trimmer a few times a little bit, but today I used it for about 1.5 hours. I went through 2 4AH batteries, which, is impressive to me, 45mins on a battery, and I was throwing tough stuff at it. I was also impressed with the performance. I'm happy and impressed with the model that I bought. I thought I paid $99, but I also thought I got the brushless motor. So I'm not certain which I got and I'm not going to run out to the garage to check.
https://www.homedepot.com/p/RYOBI-ONE-18V-13-in-Cordless-Battery-String-Trimmer-Edger-with-4-0-Ah-Battery-and-Charger-P20140VNM/315579498
https://www.homedepot.com/p/RYOBI-ONE-HP-18V-Brushless-13-in-Cordless-Battery-String-Trimmer-with-4-0-Ah-Battery-and-Charger-P20120VNM/314600636
Crowbob 07-03-2021 05:40 PM
+1 for eGO lawnmower, here.
After 25-30 years all my little gas-powered tools are at their ends-of-life. Adios, gas.
Hello electric!
dafischer 07-03-2021 07:49 PM
+1 on Ryobi 40v here as well.
21 in walk behind mower
string trimmer, with pruning attachment
525 cfm blower
Very happy with all of them. All their gas powered predecessors were out on the front lawn with a "Free" sign on them, after the first time that I used the new ones. All were gone the next day. The only thing that I need to keep the gas can for is the snow blower.
No more 2 stroke mix, yay!
dennis in se pa 07-03-2021 10:50 PM
I have been hearing good things about Ego also.
chrismorse 07-04-2021 07:47 AM
some considerations
Cordless is great, got lots, every day it seems there are new types of tools coming out cordless.
My recommendation is to first consider what tools are available from "The Manufacturer", because it seems that the batteries are all different, (not interchangeable), so, you are locked in to their brand, unless you want to have a lot of chargers and batteries laying about.
The second consideration is basically cost / durability. This runs the gamut from Harbor Fright to pro grade stuff like milwaukie.
In construction, flexibility and durability rule. I went with Milwaukie, because i used it every day and on the weekends. All those tough construction tools seem to get used on the cars too, particularly the 12 volt and the 18 volt impacts.
Good friend of mine swears by the Harbor Fright stuff like Bauer.
ciao
asphaltgambler 07-04-2021 02:20 PM
Hand powered stuff - Milwaukee has the most options off of 1 battery style. But you can opt for a larger / higher amp discharge battery for additional cost, that really sets them apart.
Aa far as lawn stuff, I have older Black&Decker weedeater / leaf blower / tree trimmer that all share the same battery. They are low priced, durable as I really overwork them. I've replaced the weedeater once, it didn't owe me anything.
Depending on your yard acreage, you might want something like Stihl battery power stuff
