Patting myself on my back
My garbage disposal stopped working. No buggy as it’s 25 years old. I have a couple in the garage because I have rentals. Pop in a new one but that doesn’t work either. So I plug it into the non switched outlet and it works. So I test the switched side of the outlet and I’ve got juice. I test the switch and again power is there. So I start tracing wires. Seems there is a pig tail that goes to the switch from three other wires. I wiggle the pig tail and power is intermittent. I replaced the bad wire and now everything works. I had to lecture my wife on how much money I saved her and why I have a garage loaded with tools and spare everything.
Oh, I’ll be saving the old disposal that still works!
Old 08-26-2021, 11:42 AM
That should help.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-26-2021, 11:48 AM
Edministrator
Steve Carlton's Avatar
Yep- all down the drain now.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 08-26-2021, 11:49 AM
That should help.
She was in a good mood so I had to take advantage as moods change quickly around here.
Old 08-26-2021, 11:56 AM
Preferred pronoun:Maestro
Norm K's Avatar
Unless the lecture is emanating from the wife, using lecture and wife in the same sentence is probably best avoided.
_
When in doubt, use overwhelming force.
Old 08-26-2021, 12:00 PM
Band.
I can hear her now
"so, you spent the money anyway? And it wasn't actually broken?"
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 08-26-2021, 12:10 PM
Really a great feeling when you figure out how to fix things
You can pat yourself 2x if you did it without consulting google or youtube.
18 Cayman GTS
Old 08-26-2021, 12:28 PM
Quite a few years ago I was on my way to work one cold winter morning with Mama and the kids waving out the front window to me. I started up my Audi 4000 and backing out I switched on the rear defogger and it immediately shattered the rear glass. Pulled back in the drive way, went around back to my shed and came back with a fresh rear glass I had saved. Went to work and installed it at lunch time. She no longer complained about my “spare part” collection!
Old 08-26-2021, 12:43 PM
This time I winged it. But, when I had to replace a three way switch it was almost a day of YouTube education.
Old 08-26-2021, 12:57 PM
hahah, yeah, 3 way switches can be a pain.
Old 08-26-2021, 01:08 PM
Zeke's Avatar
Until you encounter one with the fixture(s) in between (need 4 wires from fixture to fixture but only 3 to the switches, either end).
And then there's the 4-way. We did one of those with one switch being a dimmer that controlled the lights no matter which one you used to switch them on. Took a couple hours to figure that one out. There were 3 entrances to the kitchen.
Old 08-26-2021, 01:45 PM
As in stairs with a switch at the bottom and at the top for the lights? I can't remember if I've done that dance or not.
I've heard of a 4-way (electrical switch is what I'm talking about), and it made me shudder to think about.
Old 08-26-2021, 01:49 PM
My issue was that the original three way switch was an Eagle brand and the local hardware store only had Chinese knockoffs. They didn’t match up. Taught me about “line and load “ connections.
Old 08-26-2021, 02:35 PM
LWJ LWJ is online now
I love the lecture. I have given my wife the same one. She doesn't seem to care.
Best one is this: why does she always complain about service people. Mechanics, contractors, and similar?
Because she is comparing there crap work to my quality work.
She doesn't seem to buy that one either.
Can't win.
Old 08-26-2021, 02:41 PM
RETIRED
Joe Bob's Avatar
When you stop talking, whilst still talking, and your wife stops listening...
You are still wrong.....suck it up, buttercup.
2012 ML350 3.0 Turbo Diesel
Old 08-26-2021, 08:56 PM
The other day my wife said 'Are you even fuchhin' listening to me???'
I said, 'Slow down, that's no way to start a conversation'.
I spend a lot of time in the garage now....
Old 08-27-2021, 11:19 AM
I have encountered something similar on a three-way lighting circuit. Unlike an old three-way switch, this circuit used some sort of newfangled electronic switch that worked in a completely different way from the old ones. Took a while to figure it out.
Old 08-27-2021, 11:34 AM
The wife wants me to get hearing aids…. I love the quiet.. while she is lecturing me.
Old 08-27-2021, 12:22 PM
Zeke's Avatar
Yep, the master and the slaves. Still needs some fancy wiring. Most electricians I know will run the power/switch circuit all around the room before taking the switched power to the light fixtures. It might waste some wire, it might not. But it tends to not have to buy some 12/4 w/gr or 14 same. A little hard to find.
Old 08-28-2021, 11:36 AM
