-   -   Can I safely hide out my engine compartment? (http://forums.pelicanparts.com/off-topic-discussions/1099464-can-i-safely-hide-out-my-engine-compartment.html)
Ctopher 08-08-2021 10:01 PM
Originally Posted by Por_sha911 (Post 11417684)
Just make sure you don't use the standard Simple Green - bad things happen to certain metals.
I use P21S Total Auto Wash. PH neutral citrus cleaner and safe to use.
That’s why I specifically said simple green aircraft because it is safe on aluminum.
Zeke 08-09-2021 06:45 AM
Originally Posted by dan79brooklyn (Post 11417847)
I’ve seen on YouTube car detailers using dry ice cleaning machines. They do an incredible job. Obviously they can’t be cheap. But it looks so satisfying to see the dirt just disappear.
https://youtu.be/fHy_JpRI4lw
DI is wonderful for cleaning almost anything from suede to granite.
I used to keep engine compartments squeaky clean but not so much anymore with all the sensors. If you local clean the electronics and waterproof them ahead of time, it's better. Kinda like owning an old Brit car with Lucas.
I used a degreaser followed by detergent and then a light spray, but concentrated in hard to reach areas.
BTW, the best old time waterproofing was spray can shellac. It can be washed off with alcohol if needed. Solvents like turpentine can wash off some older engine compartment paints. Old to me is <70's.
thor66 08-09-2021 03:35 PM
do you have your own dry ice cleaning machine?
A930Rocket 08-09-2021 05:41 PM
I’ve never heard of simple green aircraft, but what’s in simple green that’s bad for what metals? I’ve not had any issues with it.
Edit: it’s great for cleaning greasy hands.
Edit 2: wow. It’s $27 vs $5 for 32 oz! http://forums.pelicanparts.com/uploa...1628556267.jpg
Ctopher 08-10-2021 02:58 AM
https://simplegreen.com/industrial/products/extreme-aircraft-precision-cleaner/?locale=en
You can find it on Amazon. It’s the only thing I use now, don’t even buy the other stuff anymore. Beyond cleaning engine bays this also works great in a ultrasonic cleaner and since it’s not corrosive on aluminum you never have to worry about how long you let aluminum soak and having to worry about corroding and causing discoloration.
CTopher
