My other ride is a C-130J
RNajarian's Avatar
Any electrical savants here?
I’ve got an electrical question for the brain trust. . .
Right to the point: What is the best way to test for an internal short in a resistor?
Here is a little background:I have a 48 V dc golf cart that I used to putter around our second home. Like my 911 there are always maintenance/upgrades to do on it.
I was in the process of replacing battery cables when I noticed the resistor that goes across the top poles of a recently installed (new) 400 amp solenoid was very hot to the touch. Normally is is cool or maybe a little warm after a ride. The resistor was new and installed 2 months ago along with the beefy 400 amp solenoid.
I tried several things to attempt to diagnose the problem, disconnecting and replacing cables, verifying I did not short anything out etc. . .
Finally I replaced the hot resistor with a used extra one I had in the toolbox. After installing the old resistor the problem appeared to go away. The old resistor remained cool and after a three-quarter mile drive did not warm up appreciably.
My golf cart forum has a number of gurus who suggested several possibilities. One of the possibilities was a bad capacitor in the controller can cause the resistor to heat up. Regardless of the cause, it does appear that the new resistor that was installed two months ago may have an internal short.
The correct thing to do now is to monitor the resistor that is currently installed and should it begin to heat up and fail then likely the problem is a bad controller causing the resistor to fail. If the resistor that was installed and is currently working does not heat up then it is fair to assume the new resistor that was installed two months ago was faulty.
Do you guys have any suggestions the best way to test the failed resistor?
Here is some additional info. I checked the voltage across the top of the solenoid and got these readings:
Cart Battery Pack: 51 volts
Voltage across the top of the solenoid without a resistor installed: 50.0 volts
Voltage across the top of the solenoid with the new resistor: 31.9 volts
Voltage across the top of the solenoid with the old resistor: 49.9 volts
Thanks for any insight you may have.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 08-08-2021, 09:00 PM
Band.
To start please measure the resistance of each resistor and report back. Unhook at least one side of its in the circuit.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 08-08-2021, 09:19 PM
RNajarian's Avatar
The new (suspected internally shorted) resistor measured 467 ohms (need to decipher ohm rating)
The old resistor measured 220 ohms (one end was removed from the circuit). This resistor is stamped 10w 220 RJ. I am assuming it is rated at 220 ohms. So this one is good.
Old 08-08-2021, 09:43 PM
They both look to be good.
What's the voltage on the coil? 48v?
The 220 ohm will draw 10 Watts, the 467 ohm will draw 5 watts. That might feel warm and is normal.
Old 08-09-2021, 08:16 AM
Send a message via AIM to fintstone
Typically a 48 V dc golf cart 400 amp solenoid uses about a 470 ohm resister and a 36 volt uses around 220 ohms.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 08-09-2021, 08:48 AM
RNajarian's Avatar
The 467 resistor was hot, it came with my 400a solenoid. The 220 resistor is cool, it came with a 200a solenoid.
Voltage over the top of the solenoid is 50.9 volts
I think you're wasting your time...but what's the rating on the green one? Is it 5W or greater?
It's very unlikely to be failing in use, but you could measure the current to be sure. My guess is you will see 0.1 Amps...
If you're worried about it, but a 467 10 Watt or 20 Watt resistor, or make a heat sink for it.
Old 08-09-2021, 09:14 AM
RNajarian's Avatar
Why is the green resistor hot to the touch and the white one is cool?
I need to decipher the markings on the green one to see what it is rated at.
Thanks guys
Rgn
Old 08-09-2021, 10:18 AM
Based on your earlier remarks...
It seems that it is likely that neither is faulty (according to your ohm meter), although the design of the 220 ohm one would allow it to dissipate heat a bit better.
As far as the voltage measurements. On the battery side of the solenoid, you should measure 50V. With the resistor in place, the other side should be almost the same @49.8ish. With the resistor disconnected, this should not be the case (unless you engage the solenoid).
Old 08-09-2021, 10:41 AM
The green one might be super-cheap borderline design resistor. Or it might be perfectly good, but designed to operate forever at that temperature.
Old 08-09-2021, 10:45 AM
RNajarian's Avatar
Without the resistor connected in the voltage is zero on the far side of the solenoid.
Perhaps the green resistor is designed to operate at that HOT temperature, but I’m not comfortable with that.
I may leave the white one in place and monitor it to see if it fails.
Old 08-09-2021, 11:46 AM
That should be correct when the solenoid is not activated...so that tells you your solenoid is not stuck closed (on)...is there a chance it is stuck open (off) or has burned contacts so that the voltage runs through the resistor vice the solenoid?
Are you measuring voltage from ground to these points? Although I don't know anything abut your cart...that does not look like the case.
Old 08-09-2021, 12:13 PM
RNajarian's Avatar
Brand new solenoid. It is not stuck closed (on)
Voltage as you can see in photos are taken over the top of the solenoid posts.
Old 08-09-2021, 12:58 PM
Platinum Member
dad911's Avatar
This. Power = (V^2)/R
What is the power rating of the green resister??
Old 08-09-2021, 01:27 PM
RNajarian's Avatar
I’m looking that up tonight…
Old 08-09-2021, 02:37 PM
UnRegistered User
billybek's Avatar
Resistance is futile...
You will be assimilated.
Bill K.
Old 08-09-2021, 04:15 PM
You do not have permissi
john70t's Avatar
"Virginia" is how I remembered it from school. V=IR.
(but there are other combos which might work better.)
Ohm's Law: Ohm's Law Calculator
A couple long wires with alligator clips and tape the DVOMs on the dash.
See the voltage change when it gets hot.
Old 08-09-2021, 05:05 PM
Bill Douglas's Avatar
Yep.
Old 08-09-2021, 05:11 PM
RNajarian's Avatar
It would appear the green resistor is 10w 470 ohms.
That is what the volt meter indicates
The 10w 220 ohm resistor is still cool.
Old 08-09-2021, 05:41 PM
MBAtarga's Avatar
A "shorted" resister - would measure 0 ohms. It would be a short - so no resistance - it would literally be the same as a piece of wire. Typically - resistors fail by going open - which is an infinite resistance - and prevents current from flowing.
Mark
'83 SC Targa - since 5/5/2001
Old 08-09-2021, 07:30 PM
