-   -   Replacement SCR? EE's Help Please (http://forums.pelicanparts.com/off-topic-discussions/1099646-replacement-scr-ees-help-please.html)
osidak 08-10-2021 06:28 AM
When I search for the specific part number I can't find anything - But honestly I am out of my depth and not sure 100% in what I am looking for
Can anyone help me find one.
http://forums.pelicanparts.com/uploa...1628601979.jpg
3rd_gear_Ted 08-10-2021 06:31 AM
Preface your search with "transistor"
Dual channel LNA module
Esel Mann 08-10-2021 10:28 AM
The squiggly T is an identifier for Teccor Electronics. Teccor No longer exists as I believe it was bought out by Littelfuse.
This link is to the datasheet.
https://datasheet.datasheetarchive.com/originals/distributors/Datasheets-35/DSA-699108.pdf
Give me a few minutes and I'll see what is available for a Littelfuse alternate or if there is any other alternate.
Esel Mann 08-10-2021 11:23 AM
I did not find a direct replacement for the S1055M at Littelfuse. It appears they have ditched their 100v and 200v (Vdrm/Vrrm) and the lowest they go is 400v. So long as the other parametrics check out, the increase in Vdrm is gooder :)
The part is S4055M and is in-stock/available at mouser.com . Here is a link to the datasheet so you can compare parametrics (to the original datasheet):
https://www.littelfuse.com/~/media/electronics/datasheets/switching_thyristors/littelfuse_thyristor_sxx55x_datasheet.pdf.pdf
NTE was my other thought. However their cross-reference tool appears to be a program that one needs to download and then register. I need to tend to some other things but if you want me to look at NTE just holler and I'll do so.
osidak 08-10-2021 12:29 PM
Thank you I will check it out
Esel Mann 08-10-2021 01:33 PM
FYI, This is what pops up as a Teccor S1055M replacement from NTE: NTE5539
Datasheet: https://www.nteinc.com/specs/5500to5599/pdf/nte5539_40.pdf
It is in-stock/available at digikey...
