-   -   Seeking Advice: Best way to frame (for concrete) a 12' diam circle (http://forums.pelicanparts.com/off-topic-discussions/1099913-seeking-advice-best-way-frame-concrete-12-diam-circle.html)
Tidybuoy 08-13-2021 10:23 AM
I'm putting in a fountain in the middle of the lawn and I would like to surround it with a small hedge and a brick curb/border.
Before I lay down the brick, I want to put in a curb or foundation for the brick to be mortared onto. I'm looking for any advice on the best way to frame a perfect circle for the concrete foundation.
Thanks!
Something like this but with a brick border at the base:
http://forums.pelicanparts.com/uploa...1628875334.jpg
john70t 08-13-2021 10:30 AM
String from center? Luan board staked in place? It's flexible.
vash 08-13-2021 10:47 AM
I see contractors do some tight radiuses (radiaii?) by using plain old plywood. they cut a bunch of shallow cut on one side so the panel can bend. they line with a flexible sheeting if they need is super smooth.
line up the circle. hammer in a bunch of forming stakes and then work the ribbed plywood around the circumference. And line with a form liner.
I do however think you can BUY a round form.
TimT 08-13-2021 10:55 AM
Thin masonite, or plywood.. wood stakes, earth back up...
Define the circle using a string..
dad911 08-13-2021 11:24 AM
You don't need a perfect circle for the base, but you need it for the brick.
Stake in the center, string with length = radius, and upside-down paint to mark.
I would form with rips of 1/4" plywood and stakes. Use scraps in between the forms to hold spacing, and pull them out as you place the concrete.
stevej37 08-13-2021 12:09 PM
Menards or Home Depot have lawn edging called Fiber Edge.
Unroll 20 feet or more and form a circle with it. It will be a perfect circle.
Unroll more if not big enough.
I have used it many times for borders/edging around large trees.
Or this....https://www.menards.com/main/building-materials/landscaping-materials/lawn-edging-tree-rings/master-mark-plastics-reg-40-black-terrace-board-landscape-edging/94440/p-1498545510922-c-13237.htm?tid=1179050337975957771&ipos=43
Tidybuoy 08-13-2021 01:17 PM
Thanks all!
The picture that I posted is of a fountain that is about 1/2 mile from my house. As I look at the photo closer, it looks like they have a concrete raised planter bed behind the boxwood hedge.
I'm going to stop by there this weekend and ask if I can measure it, because it is the exact thing I want to do in my yard. While there, I will examine the raised planter - that may be another way I decide to go.
Baz 08-13-2021 01:33 PM
I don't know why you couldn't just make the base square instead of round. You're just talking about the base. A round fountain could still sit just fine on a square base.
And it wouldn't affect the landscaping one bit. Just proceed with a "rounded" design around the square base.
Otherwise the suggestions upstream in the thread would help you get the job done, should you wish to go forward with a round concrete base.
Personally, I've been using pavers or washed shell for most stuff like that here. A lot less hassle and less permanent.
MBAtarga 08-13-2021 01:38 PM
Ask Zeke. He knows the answer....
stevej37 08-13-2021 02:41 PM
Maybe because of mowing.
I hate anything square in my yard.
carambola 08-13-2021 02:48 PM
Please remember to block out for water/power/data.
Tidybuoy 08-13-2021 02:57 PM
I want round because this will be going in a section of my front lawn that is round. Now I just need to figure out how I will do it.
id10t 08-13-2021 02:59 PM
Have you considered digging a hole and half burying a round stock tank in it. Then use the outer wall that is still partially above ground as your base for your brickwork
Baz 08-13-2021 03:14 PM
I think you're not understanding.
The outer bed can be circular.......without the need for the concrete base to be.
Draw a big circle......and inside the circle draw a square. Just make sure the circle is large enough in diameter to leave room for plantings.
Tidybuoy 08-13-2021 03:15 PM
As I think about this more, I think I like the raised bed in the center covered up with the boxwoods (however, the photo above - boxwoods need to be kept pruned). And, I am liking the nice cut circle in the grass without the brick. Sometime this weekend I'm going to stop by the house and take some measurements and take a closer look at their fountain.
My fountain is similar and has a pedestal and can sit on a very small concrete slab. Then have a raised bed which will have small plants, and then a boxwood hedge to hide the raised bed. My lawn is already bordered with boxwoods so this will fit my yard style.
carambola 08-13-2021 03:27 PM
I assume this will be a turtle habitat
stevej37 08-13-2021 03:29 PM
^^^lol
they are ok with six-sided homes...but not square ones. :)
Tidybuoy 08-13-2021 07:00 PM
Ok I got it. I will decide after I take a look at what the neighbor is doing. I don't think I will get to this for about a month so I have time to think and rethink and then think it again.
ben parrish 08-13-2021 07:50 PM
Why frame...dig a footer as in dig the circle...the sides become the frame and you don’t have to worry about framing blow out or having it perfectly round.
look 171 08-13-2021 07:53 PM
Dang Vern, you are just jsut busy man with projects around the house. Good luck.
