Buying a Golf Cart
Wife’s wanting to buy a “newish” golf cart. We have driven plenty of them on vacations but other than that don’t know much about them. Thinking of a gas power slightly lifted 4 passenger that is street legal. Anything to look out for? Is electric an option. I don’t want a slow cart with no power and we will be taking it off-road. Any insight?
78 911 st backdate
87 944
00 996
Old 08-23-2021, 10:15 AM
Banned
gas models will do 30 with the gov rigged
el can go fast but requires costly parts swaps Li battery is trick but costs
like most other stuff get one DONE used is far cheaper then buying bits
https://www.buggiesgonewild.com/ is a mostly golf cart site
Old 08-23-2021, 10:29 AM
(the shotguns)
berettafan's Avatar
Bought an ezgo gas from a guy who had picked it up used from a golf course. added slightly bigger wheels/tires, rear seat and gun racks along with a front basked. It's gas and i would not bother owning electric (charging considerations and batteries to replace every few years at great cost).
I have about $4k in mine. Usually see late model rehabs (bigger tires, lift) for around $8k.
Old 08-23-2021, 11:29 AM
Seahawk's Avatar
There is so much stuff out there...they hot rod the f out of those things.
Good luck!
https://sidebysidereviews.com/golf-car-review/
1996 FJ80.
Old 08-23-2021, 11:41 AM
My only experience with golf carts is on the golf course (but that’s considerable) my only tip would be the gas carts are noisy compared to electric…some so much so that it’s difficult to hold a conversation. Some gas ones may be better than others but you should try before you buy.
Old 08-23-2021, 12:10 PM
Brew Master
cabmandone's Avatar
IIRC when I was doing my search the consensus seemed to be EZ-GO and Yamaha for gassers.
I bought one for my parents like the one berettafan posted.
Nick
Old 08-23-2021, 01:32 PM
Just started shopping them and can’t believe the prices I could easily buy a 944 and some hit turbo money.
78 911 st backdate
87 944
00 996
Old 08-23-2021, 03:24 PM
Brew Master
cabmandone's Avatar
Oh yeah! The pimped rides aren't cheap! I've seen them around here for 10-15K depending on how pimped they are. You go full on lift, big tires and wheels, premium body kit, premium sound system and a tweaked engine... and things can get out of hand pretty fast.
There's a darn good reason my golf cart reads "Polaris Ranger 900 XP EPS" on the side.
Nick
Old 08-23-2021, 03:29 PM
FUSHIGI
Seems like the nihilist “Unpimp ze ride” VW commercial guys could rightly have an issue with the modifieds.
Cults require delusions.
Old 08-23-2021, 04:51 PM
wdfifteen's Avatar
The carts we use here are both stock electric. They are almost never on pavement, but not exactly bushwhacking here on the farm. I think we have maybe $5k in the two of them, including $1600 worth of new batteries.
Old 08-23-2021, 04:56 PM
(the shotguns)
berettafan's Avatar
btw, if you mean truly off-road then skip the cart and go with a UTV. anything rougher than a decent lawn requires going very, very slow in a golf cart.
Old 08-23-2021, 05:24 PM
By off-road I meant groomed trails or rock and dirt driveways not wanting a true off-roader.
78 911 st backdate
87 944
00 996
Old 08-23-2021, 05:52 PM
My other ride is a C-130J
RNajarian's Avatar
Who are you calling a Pimp?
This is my 48v street legal 4 passenger ACG H3. 15 inch wheels, Top speed 25 mph. I would consider what the local laws are where you live.
Technically in California carts driven on the roads are required to be registered and insured. If you’re just driving it in a gated community you may not have that requirement. I have not been able to find out exactly what the registration requirements are with gas carts in California. I have heard they need to be visually inspected at the DMV which would be a real pain if you have to put it on a trailer and take it to a DMV for inspection every two years. My cart is electric so I am exempt from that smog check.
I primarily use my car to drive around the marina go out to dinner run small errands. My range is about 20 miles. If I opt for the lithium upgrade (for $2,000 the range could be bumped up to 40-50 miles per charge.)
Gas carts can usually sit for extended periods of times with no maintenance. Electric carts especially if they’re using lead acid batteries will need to be constantly plugged in so that the batteries be maintained in the off months. Electric carts will need to be maintained every month by having the water levels in the batteries checked. Batteries that go dry or allow the state of charge to go below 75% may require a new battery pack at about $1000.
If You check Classifieds in communities that have golf carts for example around marinas, golf courses and retirement communities you may find a deal. My neighbor bought a used Yamaha gas cart for $200 and spent about three or four grand completely tweaking it out and it is impressive!
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 08-23-2021, 06:08 PM
wdfifteen's Avatar
You don’t need anything special. A stock cart will do fine. We carry heavier loads than they were designed for over pastures and cow paths in our stock carts all the time. “Lifted” is just for show.
Old 08-23-2021, 06:40 PM
Brew Master
cabmandone's Avatar
Rn,
It ain't "pimped" till ya got spinners!
Your ride is more "tricked" than "pimped"... there's a difference!
Nick
Old 08-24-2021, 03:58 AM
This is my rig use it for patrolling and yard work. Paid $1300 at an auction a coat of raptor bed liner, lift, wheels, led bar and power clutch kit. All in $2000.
Old 08-24-2021, 05:17 AM
peppy's Avatar
We picked up this 2018 Club Car for $6500. It is a 48v electric. I was told the gas carts can over heat the engine on long runs.
I was told golf would relax me BS!!
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 08-24-2021, 05:21 AM
For the most part your right. Lifted carts also tilt the motor back from stock which can cause carb float issues/ flooding. Lifted carts also handle like crap. I need a lift to get across some streams on the property.
Old 08-24-2021, 05:22 AM
LWJ LWJ is online now
My cousin bought one for his disabled wife. We mowed trails all over the farm. It is a BIG hit! It is an electric EZGO. Small lift and knobby tires. Shockingly capable and silly fun.
Old 08-24-2021, 06:42 AM
RNajarian's Avatar
If you are considering going electric, educate yourself on the lithium battery upgrade, increased range, decreased weight, faster charging than lead acid batteries.
Old 08-24-2021, 06:47 AM
