biosurfer1's Avatar
Installing concrete anchors on large, existing pergola?
I have an existing pergola on my property sitting on concrete that does not have existing concrete anchors holding it down, even though there are post brackets there (No idea why they are missing)
The post brackets look similar to these:
My question is being so large, I can't see a way to move each post out of the way to hammer drill the holes for the concrete anchors, so is there a way to just drill the holes through the post bracket holes? Or do all anchor holes need to be bigger than the bracket holes?
I've only looked at a couple concrete anchors but all of them were a larger diameter than the bracket hole, so I figured that was a no go...looking for suggestions. Thanks!
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 08-25-2021, 10:33 AM
Idea:
1 - unbolt existing structure and move it over 1 foot in any direction
2 - using a hammer drill - drill correct size hole for ? 3/8" concrete bolts, remember to clean out the holes very well using compressed air (you can use one of those air cans from HD). The compressed air cans come with a straw that allows getting to the bottom of the hole and forcing the dust out, you can also use another object to help get all the dust out along with the compressed air.
3 - move structure back while installing the new brackets
4 - install the concrete bolts/screws
Sold: 1989 3.2 coupe, 112k miles
Old 08-25-2021, 10:41 AM
e.g. Screws - Tapcon 3/8" x 3"
Old 08-25-2021, 10:45 AM
biosurfer1's Avatar
Originally Posted by hcoles View Post
Idea:
That was my plan, but moving it a foot out of the way could be troublesome. It's blocked on 3 sides by concrete stairs/built in planters and a iron fence. The bigger issue is this damn thing is heavy and the posts barely move independently of each other (otherwise I would treat it like a 6 legged dog, slowly moving each post one at a time)
2006 Lexus LS430 ML
Old 08-25-2021, 10:48 AM
biosurfer1's Avatar
That is my plan B, but I have some concerns that concrete screws can handle that kind of load (though it's better than the nothing that's currently holding it down)
It would be 24 screws holding it down (4 per post x 6 posts) so maybe i'm over thinking this. We get windy here but no hurricanes/etc
2006 Lexus LS430 ML
Old 08-25-2021, 10:53 AM
ah, okay. Maybe try jacking the whole thing up one post at a time until it is high enough? That could be troublesome.
Another idea, maybe not a good one, cut off each leg and insert new leg piece with new bracket that matches the cut off length. Then put a gusset, of some sort, across the cut line.
Old 08-25-2021, 10:54 AM
Brew Master
cabmandone's Avatar
I'm not followin ya. You should be able to buy an expandable anchor that will fit the hole size you decide to go with. So if you want to use a 3/8 anchor, you drill the appropriate hole, drive the anchor in the hole, then put the nut on and tighten to the spec necessary to set the anchor.
I'm talking about an anchor like this only not necessarily that size.
https://www.grainger.com/product/15X102?ef_id=CjwKCAjw1JeJBhB9EiwAV612y07G7IBOsKBmi OJe5bxThqyEN1oc4_wyl9OjnmBxmvcnYtku0b7r1xoC-MQQAvD_BwE:G:s&s_kwcid=AL!2966!3!281698275318!!!g!470148656870!&gucid=N:N:PS:Paid:GGL:CSM-2295:4P7A1P:20501231&gclid=CjwKCAjw1JeJBhB9EiwAV612y07G7IBOsKBmiOJe5bxT hqyEN1oc4_wyl9OjnmBxmvcnYtku0b7r1xoC-MQQAvD_BwE&gclsrc=aw.ds
Nick
Old 08-25-2021, 10:55 AM
Expandable anchor sounds good also, maybe stronger.
Old 08-25-2021, 10:57 AM
Brew Master
cabmandone's Avatar
Yeah. I'd probably put two in each post bracket and call it good. If he really wants to go all out, pop all 4 in but with the right size I think two in each post would be sufficient.
I would have no real issue with a tapcon though. Those things are pretty strong.
Nick
Old 08-25-2021, 11:01 AM
biosurfer1's Avatar
That should work great. Don't know why I wasn't finding that earlier. The only ones that were showing up under my search were more like inserts that epoxied in the hole, and all the inserts were a larger diameter than the bracket hole.
Thanks!
2006 Lexus LS430 ML
Brew Master
cabmandone's Avatar
That's what we're here for! Glad I could help.
Nick
Old 08-25-2021, 11:03 AM
The Unsettler
stomachmonkey's Avatar
I think the issue is the holes in the plate are smaller than the holes he needs to drill for anchors.
So my thought would be just drill the plate holes larger.
Use a larger washer on the anchor bolt.
But then does the plate need to be sandwiched between the anchor and bolt?
Not a mechanical engineer but logic says if sandwiched the plate helps spread load?
As in if the anchor fails it can still pull through the plate?
Honestly, I'd not be worrying to much about it.
If it's too large and heavy to move without equipment is it really going anywhere?
What value do the anchors provide at that point?
"I want my two dollars"
"Brandon Won"
Old 08-25-2021, 11:04 AM
Use a couple brackets like these, one on each side of the post and run a bolt through the post. Try and find some where the holes that are drilled on the bottom leg are far enough out from the post that you can actually get a drill perpendicular to the ground and drill the holes. If you can’t find them, make something just like them.
Old 08-25-2021, 11:06 AM
Brew Master
cabmandone's Avatar
BTW, are you sure they didn't put an anchor inside the bracket before setting the post? Some brackets have that option. What I mean is, just because the holes outside have nothing in them doesn't mean there isn't something tying the bracket to the concrete.
Nick
Old 08-25-2021, 11:14 AM
Those look good or get post anchors with 3 sides or 2 sides. E.g. VITA Bolt Down Bracket System. I found on HD.
Old 08-25-2021, 11:19 AM
I like the A24 Simpson idea. The VITA doesn't have tabs sticking out across the concrete.
Old 08-25-2021, 11:21 AM
908/930's Avatar
I can't tell the diameter of the holes, I find the Simpson site is a pain. A long 3/8 hammer drill bit will get in there easy, and a 3/8 Wedge anchor is good for about 4000lbs in tension when set properly. I just looked they have 3/8 SDS drill bits up to 39", can just stand there and drill. LOL
Old 08-25-2021, 11:50 AM
Wedge anchors are dead simple, cheap, and strong.
Old 08-25-2021, 12:44 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Even simpler is drilling the same size holes as the bracket without moving anything and then install all thread using concrete epoxy. No need for anchors and they make concrete epoxy that will take the load. That's one method used to install anchors to house foundations that never had them originally.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 08-25-2021, 01:00 PM
biosurfer1's Avatar
PLEASE tell me you have a good argument that will convince my wife of this
Using a hammer drill and setting 24 anchors seemed easier than winning that debate against a non-technical, non-engineer person who only envisions it being blown up in the air and landing directly on my son's bedroom.
2006 Lexus LS430 ML
Old 08-25-2021, 01:21 PM
