install tubes in zero turn caster tires, problems?
The front tires on our zero turn have started leaking. They are tubeless.
I've had good luck in the past with smaller stuff, like dollies and wheelbarrows installing tubes. Is there any good reason that I shouldn't install tubes in the front/caster tires? |
Are there any wear/friction issues between the tube and inner tire?
Securing the location of the new valve stem? |
That's a good question. I wouldn't think there would be any major issues with friction once fully inflated.
I was a bit wondering about the valve stem. |
-Fully bonded to the inside of the tire. Use a flexible, rubber-safe, non-hardening adhesive. The soft inner tube still needs to stretch extremely at the "V" leverage points when the thick hardened old rubber tire runs over a sharp obstacle. or -It need to be fully free-floating. Maybe a ton of talcum powder/graphite powder. Those make break down rubber eventually. Or a silicone lubricant oil fully wiped on thick with a brush. This may still pull laterally at the valve stem. Rubber glue could be added next to it on both sides. The rest lubricated. |
Look at the price of tubes. Then look at the price of new front tires. Then look at the hassle of installing the tube vs new tires... I'd just put new tires on and be done with it.
Let me correct myself.... First, where are they leaking from? Is it from something piercing the tire, cracks in the sidewall from age, or around the tire bead? I had a tire that leaked because the valve stem cracked. |
Other option (and the easiest) is a can of fix-a-flat or tire-goo.
If it's coming from the Schrader valve stem those probably shouldn't be used. $2 replacement fix. Spray some soap/bubbly around the rim and valve stem, first, and make sure that where the leak is coming from. Deflating. breaking the bead, rotating slightly, using tire sealant, and remounting will do the same trick. It's a low speed industrial application so not too much science involved. |
Another easy way to find the leak on a tire that small is to fill a 5 gallon bucket with water and roll the tire in the bucket. When you see bubbles, you know where to start soap checking. |
Harbor Fright replacements?
Need general wheel diameter, axle diameter, rim width for securing it. Big fender washers and/or sleeves are your friend. |
lately iv been using antifreze for cracked tires. Seems to work as well or better than slime or whatever else. Just pull out the core put a hose and small funnel on the stem push the tire in so it sucks the coolant in.
Lots of good stuff folks, thanks.
I gave up on Slime in my wheelbarrow and bought a Chinese tube. It was surprisingly easy to install. YMMV on a smaller tire.
Word of advice, keep the tires on, let out almost all of the air and try to break the bead. Those things can be really stubborn. They're typically designed to run on lower air pressure than something like a soft sidewall wheelbarrow tire.
We have a habit of overthinking things here . Tube those mothers, and get mowing . !
Good advice from Cabby , breaking the bead will be the hardest part . |
Thanks folks.
Reviving an older thread.
1 Getting the tires off to install tubes is a HUGE PITA! 2 Getting the tires back on is also a huge PITA, and the first time I gouged the tube, LOL. I've replaced the tube 2-3 times. They keep going flat. I'd say tubes are a bust. There are a slew of cheap Chinese wheel/tire assemblies on Amazon, but I don't want to go that route. I can get just tires. They'll be made in China, but at least I can get Carlisle which I think is a decent brand. I can get OEM which would probably be $300 for both front tire/wheel assemblies I can get "NoAir" branded for $249 which have the following description. Quote:
I broke down and took a chance of the "NoAIr" branded tires. They seem well made. You have to grease them before installing them. I suspect that most of the folks that complained of failures did not grease them, or did not adequately grease them. I ran the grease gun until things started moving. It ended up taking a whole 14oz cartridge of grease, but on both sides, the bushings started pushing out after much pumping. On the first side, I monitored watching for when grease started pushing through the bearings. Hopefully, these last a while.
In case anyone was curious, the "noair" brand (company is based out of Waco, TX, but parts are sourced from China, I'm sure) is one of the new "semi-pneumatic" tires that are marketed for the front of riding mowers. They are basically foam filled. A bunch of folks have videos on YT where they make their own from great stuff and that sort of thing. I considered that, but it sounded like a PITA. These do have some give like regular tire, but they are stiffer. I've never driven a car with run-flats, but I imagine it might be similar. I've seen some folks complain that they are stiffer. It's a mower, and I don't think the front is sprung (or has much weight on it anyway). I rode it around for 30 secs. It didn't seem crazy stiff. If I can stop airing up the tires every week, I'll be happy.
There's a reason I take the smaller tires to a tire place and have them install them and it's not because I don't know how to do it!
I'll have to look into these "no air" tires |
13 year old Toro zero turn caster tires started leaking. Removed them (easy) and took to local tire store. Had tubes installed. Reinstalled wheels. No leaks for over a year.
Hopefully, these foam filled tires last a nice long time. |
I think the issue is that we have Huisache aka Sweet Acacia, here which can get up to about 15' tall, but they pop up in the wilder portion of the yard, and... https://watershedmg.org/sites/defaul...-wikipedia.jpg |
Those look bad, but not Locust bad. |
You wouldn't believe how many pair of waterproof hunting boots I've had ruined by those damn locust thorns. I quit wearing my hunting boots into the woods for anything but hunting. |
| All times are GMT -8. The time now is 09:22 AM. |
