How to heat up a plastic rod to bend it?
I bought a 2003 M3 with the SMG transmission. While the paddle shifters are nice, I find that when making certain turns, I can’t shift with the paddles, due to the steering wheel having rotated so much.
Because of that, I want to be able to shift with the shift lever at certain times. With my race seat so far back and I’m strapped in with a harness, I can’t quite reach the shifter. So, I bought a taller shift knob, but I want to angle the shift lever back some. It would need to be bent between the rubber boot and the thin round stop(?). What is the best way to heat it up without damaging the integrity of it? Edit: i’ve done something similar with metal shelf levers, by heating them up, bending and welding an extension on them. Here’s the shift lever mechanism. ![]() ![]()
Any idea what material it is made from? I am surprised the shift rod is not metal. If plastic it is possibly glass loaded nylon, if so nylon melts at a fairly high temp approx 500f for 6-6, so somewhere near that it should be bendable, if it is glass loaded that could change things, are you able to remove? Is it possible to just mount the assembly farther back?
If you could find a thin enough band heater you could just heat up that section. If it is epoxy carbon you are not bending it.
87 930, Last edited by 908/930; 09-28-2021 at 08:04 PM.. |
Model Citizen
Heat gun?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Whoopsies I was banned!!!
Based upon what the op describes, and lacking dimensional info of what it currently does and what the op needs it to do, would bending it be enough? Strapped in a seat, one loses both vertical and horizontal. That is bending would provide additional horizontal gain but increase vertical reach ( hence op's mention of extension with metal shifters).
Information Junky
Pretty much what 908/930 said... You need to know what category plastic first - thermoplastic or thermoset.
If it is a thermoplastic (possible) understand that plastics are very slow to move heat, and the heat deflection temps are all over the map. - You need to know what plastic it is. And even then, I doubt it will act as you expect.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Why not just use one of the longer aftermarket levers? Price?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
I’ve not seen a longer aftermarket shifter. Making it longer/taller doesn’t help, as I need it brought back, to reach it better. |
I would think you’d be better off fabbing up an offset shifter that brings the knob up and back to you. Cut the existing shifter and attach the extension with epoxy and a sleeve.
^^^exactly my thoughts.
Epoxy saves the day! |
RETIRED
They had those in old VW buses....raises the knob and back towards the driver. If you're handy easy fabrication. Or hire a job shop to do the deed.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Registered ConfUser
I’d be apprehensive about the whole bending/bonding concept especially with plastic. Would hate for the shift knob/half shaft to come off in your hand at 8k rpm’s.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
"How to heat up a plastic rod to bed it?"
Maybe start with a nice meal and some wine. You could also have a little Luther Vandross playing in the background.... Once you get it hot, what you do with it is up to you. We probably don't want to know.
Counterclockwise?
Move the seat up.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I need to get my eyes checked...
I read: "How do you heat up your plastic rod in bed"
Ole Skool - wouldn't have it any other way |
It's always best to have an assistant.
Fire, match, bic lighter, dragon breath maybe?
"A little nonsense now and then is relished by the wisest men." Wonka |
The only way I know of to determine material is to do melt and burn tests, not easy. Possibly take a metal file to the top edge of the shift arm, nylon does not give a nice finish it sort of machines like rubber, plastic radiator tanks are usually nylon for comparison. I would just take it apart remove the arm and modify or remanufacture from there, it looks like the assembly is fairly cheap for a used one on line.
87 930, Last edited by 908/930; 09-29-2021 at 09:50 AM.. |
I'm sure that a fist sized blob of JB Weld would do the trick! (OK, it would, but who wants that)
Local CNC or machine shop make a new arm for you?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
I don't know anything about the M3 shifter but why 2 pieces? If this were my project I'd be looking at what I could do with the upper piece hoping that it will release from the bottom piece. And if I sat if that car for the first time ever, I would have a tendency to think that pushing down on the upper piece is the reverse lockout. I guess not though if you were planning to bend the lower part. Anyway, see if it unscrews. |
