The Unsettler
What size nut?
On the left that holds the steering wheel lock assembly in place.
84" 911 It's slightly under the knee pad and wiring all over the place. I'm dont do well in cramped spaces so trial and erroring sockets is not working for me. We looking at a 17MM? Thanks
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I'm gonna GUESS that it's closer to 15mm.
My recollection of changing out my ignition switch on my '78 SC is foggy at best but I don't think I used anything close to 17mm when doing it.
Scott '78 SC mit Sportomatic - Sold |
The Unsettler
Kinda why I want to know the size for sure.
You'd probably get a better, faster answer on the 911 tech board than OT.
The Unsettler
More eyeballs here on it already than there. ![]() ![]() ![]() Maybe they think I'm a newb because I haven't posted there in 15 years or so.
The Unsettler
OK, so its a 13mm
Got it off but still can't slide the assembly out. Steering column lock is not engaged so what's holding it in there on that end?
The Unsettler
Does that bolt have an allen key slot in it and the bolt is just the lock nut?
It's an M8 nut so it takes a 13mm wrench
Tru6 Restoration & Design |
I am pretty sure you need to remove the knee pad. 8mm socket, there are 3 of them. Universal joint helps with the one closest to the door.
You need to loosen the allen head grub screw. An allen wrench with ball end woks a charm
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Then, you need to take the lock assembly, put it in a vice, and cut 80% off of it.
The steering wheel lock assembly will eventually fail and bind, so why keep it? Lop it off, be free. Being able to turn the steering wheel without the key is in SO LIBERATING. Kinda like being able to turn the engine over without having to press the clutch.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
The Unsettler
The cam that disengages / allows the locking bar to engage is not functioning correctly. I have not pulled the guts yet but it feels like a circlip or retaining mechanism is bad allowing the cam to float and bind. I can see it happening with the cylinder out, just can't see under the cam yet to see what failed or if it's just worn out. The cam follower attached to the lock cylinder then loses contact with the lobe allowing you to turn the key back to full off but the ignition switch attached to the cam stays in run position.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 10-06-2021 at 07:20 AM.. |
The Unsettler
Probably what I will do.
Have a line on a replacement part that's actually a reasonable price. The ****ing thing is $1,000-1,200 new. And then you need to rekey which sucks. I can find used ones but people are asking really stupid money for them and you have no idea of the condition and you worry am I just buying more broken. They do give an indication that they are failing but I drove mine for years with it in a prefail state and you kind of get used to it so who knows what a sellers impression of "works fine" may be?
Don't know. I did this back in the '90s when these cars were cheap and I was simply looking for the easy solution. Five minutes with a hacksaw and I re-installed it. It's been fine ever since.
abides.
![]() Hadn't thought of cutting the thing apart... that is tempting, but i do like the security of the wheel lock for situations where i'm parked on a hill and have the wheel turned toward the curb. I trust the wheel lock a lot more than my e-brake.
Graham 1984 Carrera Targa |
The Unsettler
The annoying part about the whole unit is it seems the lock cylinder and associated levers / cams all rely on being sandwiched together so removing the lock bar portion may not help address anything but rather make things worse. I have an idea on how to make some retrofit pieces to address it but don't have a desktop mill handy at the moment.
