[QUOTE=jyl;11488794]... I guess the prior guy threaded it on at the elbow, not sure.
.../QUOTE] Most likely. That would be typical. Good work. I was afraid you would hesitate...as it sounds a bit crazy to use a flame if you have not done it before. I do that after any install to check for leaks when I first turn the gas back on (making sure I have cleared any gas from the room first). Of course I am self taught and just telling you how I do it. Might not work for everyone...so I always recommend others hire a pro. That was a pretty good sized leak. Good thing you took care of it. |
Thanks fint,
Everyone here is your nightly bulletin - jyl has not blown up yet |
| All times are GMT -8. The time now is 07:27 AM. |
