Looking at a 1966 BMW R60/2 W/Side Car
Next week I'm going to look at a 1966 R60/2 with Steib side car.
Original paint bike with 37k on the clock "some upgrades" The sidecar is not in the same condition but was new with the bike. First time looking at a BMW I owned/restored and still have vintage Harley so familiar with the old bike issues. Anything I should ask or look at on my visit? I so far will inquire about the oil slingers, check the 3 VIN numbers and receipts for what repairs and upgrades were performed. Swayer |
and I thought my R50/5 was slow
I never had a /2 and they are significantly different from the later models
I don't think they have an oil filter they have a roller crank balancing carbs and adjusting valves should be the same you may get tired of the novelty of the sidecar because its going to be so slow and even dangerous to ride on roads with traffic you will have to have one eye glued to the mirror |
(the shotguns)
Slinger in lieu of a filter.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Registered ConfUser
Really? Explain.
The slingers are responsible for oil distribution. It doesn’t filter or clean anything.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
From what I understand the slingers act as a centrifugal catch for particles with no way to clean without a tear down. But I am new to BMW.
My current bike is a 1954 Harley KH and that is a bit on the slow side so not really a speed demon I have a 911 for that. The side car would be new to me, never drove a bike with one. Sawyer |
Zink Racer
From the bmwmotorcycletechinfo.com site
"There was no oil filter such as a paper pleated filter, as there is on the 1970+ Airheads. On the /2, the oil from the oil pump was 'filtered' by sending it into closely separated plates or plate and backing, that were part of the crankshaft assembly. One plate is called a slinger, where the harsher of the contaminants would be deposited into a hard layer along the edge of what was actually a shallow cup. The capacity of the cavities was limited. If the slingers were not cleaned at reasonable intervals (you will not think the mileage reasonable! ...30,000 miles!), the slingers could fill-up, clog the oil passageway, & some very expensive engine parts would be ruined"
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
(the shotguns)
The outer rim is a crevice that catches gunk.
Registered ConfUser
Ha! I think we’re both right. Bottom line...oil changes are easy on that bike. Do them often!
Registered ConfUser
Not sure where you’re located but guessing this is the bike.
https://asheville.craigslist.org/mcy/d/sapphire-bmw-r60/7389790458.html Wife and I were in Black Mountain, NC last weekend. Asheville is 10 minutes down the road. Had I known, would have been easy to stop and have a look. I scratched my sidecar itch with a Ural a couple of years ago. Definitely a different riding experience. If you have kids/dogs that will be your hack monkey (yup) it could be good fun. That bike won’t lose value so you don’t have much to lose. So I vote “yes”. Should be good fun along with plenty of weekend/evening tinkering. Keep us posted.
Friend of Warren
I have a 1965 R60/2. So I do have a little experience with them. He is asking top dollar for that bike and sidecar. With that in mind, I would want to see some receipts for the maintenance that has been done over the years and proof that it really has the mileage he states. It would be nice if he had some proof that the slingers had been cleaned out sometime over the years, but that would not be a dealbreaker for me.
All /2s havethe mounts for a Sidecar. But if it was originally set up to run with a Sidecar, it will have different gearing. It will also have the front shocks set up in the correct hole on the Earls fork.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Yes Chocaholic that is the bike. The wife saw it on Cycle Trader and ask me if it is what I had described for my next bike.
There has been regular maintenance done on the bike with years of receipts. Without going into all the details the engine was serviced with new pistons, rods and slingers cleaned, tranny, kicker, carbs serviced plus more..... About a year ago converted to 12 volts and electronic ignition. Is a bit rougher in real life but shows genuine use. Started from cold with one kick. Power, shifting and handling no issues Couldn't pass it up it hit all the marks for me. Also original tool roll, owners manual and a newer repop of the original 4 language repair manual and one in English only. New adventure!! Sawyer |
Or if the bike has just been sitting too long.
1971 R75/5 2003 R1100S 2013 Ural Patrol 2023 R18 |
Registered ConfUser
Reading a bit between the words...so, did you go see it? Are you the new owner? If so...pics! There’s an R50/2 for sale in Atlanta that looks interesting...but way over priced. I owned a 1954 R25 a few years ago. Fun little adventure but that bike was purely a novelty as it wasn’t really capable of modern roads or speeds much above 50.
(the shotguns)
I told my wife about this thread and she was enthusiastic about you getting it, so we’re both glad you did. She coined the term “ice cream car,” meaning a car who’s purpose is to take it out on gentle runs, preferably to and from the local ice cream stand. This will be the perfect ice cream cycle. Let me know if you ever need a copilot in the sidecar when you make an ice cream run. I’ve always wanted to ride in a sidecar.
I don’t know if you’re a Doonsebury fan, but this is the bike/sidecar combination that Mike Doonsebury and Mark cobbled together for their summer ride across America. They ended up picking up Joanie on the road somewhere and somehow fit her into the sidecar and brought her back to Walden. It’s worth getting just for the Doonsebury connection ![]() Here’s a link to the original series. https://www.gocomics.com/doonesbury/1972/07/27
MRM 1994 Carrera Last edited by MRM; 10-18-2021 at 04:48 PM.. |
I did get the bike home titled and riden. Bit of a learning curve. I need a bit of ballast before I start putting around with the wife. Got to pay attention to the far right side.
I used to run a 1955 Harley 3 wheeler so the steering concept isn't too alien to me. My other bike under resto now is a 1954 HD KH I've had this one about 25 years and needed a refresh. So I'm used to slow bikes The bike is original paint and very nice with lots of receipts. Also the original drivers manual, tool roll and shop manual. The sidecar needs resto but that can wait. The S/C is not original to the bike appears a bit older and way different patina. The bike is set up for it but need to verify the gearing. Good wife for sure. The 79SC was hers, she always wanted one, found it bought it and drove it. It was hers. When she wanted more comfort and open top she bought a MB SLK350 and handed the Porsche down to me. She searched far and wide for the SLK as she needed it in blue with a three pedal 6 speed tranny. The same as her blue Dodge Ram with a 5 speed on the floor. Sawyer Last edited by Sawyer911; 10-23-2021 at 07:55 AM.. |
Oh and a pic .....
![]() ![]() Sawyer |
That is so cool. I’m glad you got it.
MRM 1994 Carrera |
Feelin' Solexy
There are some really good books on sidecar/sidehack riding, worth the investment. They are super fun (and my kids loves when I fly the car) but you need to train yourself to go into "sidecar mode" so you don't fall back on your 2 wheel training. Good luck and be safe!
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
