-   -   Any one familiar with NB Miatas. Need help badly. (http://forums.pelicanparts.com/off-topic-discussions/1106358-any-one-familiar-nb-miatas-need-help-badly.html)
DWBOX2000 11-09-2021 08:13 PM
My sons Miata was having starting issues. It would be intermittent starting problems. Well one day it just wouldn’t start. Unlike my other cars, I just threw parts at it hoping I would get lucky. New MAF, spark plugs, coils packs, wires, PCV valve, cam sensor, fuel filter, fuel pump. Didn’t fix problem. Anyhow, I start cleaning wires. Eventually I clean the engine ground and it has been starting great ever since. Now, when I come to a stop after warning up a bit, the rpm’s will often drop to 200 when I come to a stop. If I am in gear at 3k or more and put foot on clutch to stop, this problem seems to occur. If I am at a lower rpm, not so much. If I drop into neutral it is usually fine but will act up sometimes. At 200 rpm’s it either dies after sputtering there for a few seconds or putts back up to 1,000. There are no codes. I drove to work this morning (20 mins) and it seemed to be fine when fully warm . It actually was idling at 800 rpm’s. Could just be luck. Also, it drives great when going. Never dies when driving. Any suggestions? I am out of ideas. I tried spraying starting fluid when cool and running, no change in revs.
Thanks.
unclebilly 11-09-2021 08:16 PM
Throttle body.
DWBOX2000 11-10-2021 03:36 AM
I cleaned it.
I’ve been on the Miata board which not much luck btw.
stomachmonkey 11-10-2021 07:57 AM
If you suspect a grounding issue run a battery ground cable straight from the MAF.
It's actually a common pretty much "free" upgrade.
I ran an extra ground from MAF on my Mazda 3 and the car did run noticeably smoother and pretty much eliminated the fly by wire throttle lag.
EDIT: quick search, 1st hit.
https://maxima.org/forums/4th-generation-maxima-1995-1999/376649-finally-fixed-stalling-issue-grounding-maf-sensor.html
ZOO 11-11-2021 07:08 AM
I added a beefy ground strap from the head to the body on my NA and fixed a lot of little niggling issues. My original ground strap was in good repair, too, but clearly something wasn't right.
Instrument 41 11-11-2021 07:18 AM
With all those parts replaced you might have put on an inferior part, if this was not an issue before. Measure tice, cut once.
DWBOX2000 11-11-2021 12:10 PM
Wasn’t by best move. I need to figure out how to test parts. Thanks All!
DWBOX2000 11-11-2021 12:12 PM
I can swap each part back except for MAF. Guess I can do one at a time and see what happens.
