-   -   2007 Xterra cooling system puzzler (http://forums.pelicanparts.com/off-topic-discussions/1107054-2007-xterra-cooling-system-puzzler.html)
Bob Kontak 11-26-2021 01:48 PM
Originally Posted by drcoastline (Post 11529781)
I don't know where to go next but the water pump? I would think not if I have heat?
I wanted to see if I had flow through the engine but not sure how to go about that?
Edit: and I would guess maybe the thermostat isn't opening due to the curren temperature here 44 degrees? Although it was in the sixties yetserday. If the thermostat isn't opening no flow through the block correct?
Water will not flow through the block and you will not have heat at least based on old school systems.
Your thermo will open if it's 80F outside.
drcoastline 11-26-2021 02:26 PM
So since there is heat (when th sytem is full of fluid) thermostat is openin g and water pump is pumping?
Scott Douglas 11-26-2021 03:56 PM
This thread reminds me of a problem I had with an old Alfa Romeo. It had a hose that would bypass the radiator so water would circulate in the block to help warm it up faster. This hose had a spring loaded valve in it that would be opened when the thermostat was closed by the water pressure being pumped by the water pump. When the 'stat opened it would close, diverting the water to the radiator to be cooled. I got hold of another car, same model etc. and it didn't have that diverter valve in the bypass hose. Car ran hotter than normal, especially in the 120* temps out in Palm Springs where I bought it. Put a diverter valve in the system and it worked fine. That along with removing the defunct A/C condenser some idiot mechanic left sitting in front of the radiator when he removed the A/C system helped a lot.
I find it odd that your engine wouldn't circulate coolant in the block until the thermostat opened. I've also never run across an overflow tank that is part of the pressurized system either.
Learnin' stuff every day here on PPOT.
Wish I could help more.
drcoastline 11-26-2021 05:05 PM
I don't know the answer to this. It was a question. Thermostat is 180 degree so Assuming the engine doesnt come up too temp thermostat doesn't open? and coolant doesn't flow?
Again, the initial reason this vehicle failed inspection was it was running cool.
oldE 11-27-2021 05:04 AM
The usual reason for running cool is a thermostat which is stuck open or is opening too soon. I have heard of new thermostats out of the box which were defective in this fashion. The way to test is to immerse the thermostat in water with a thermometer and increase the temperature until the unit opens.
On the other hand, in my experience big temperature differences between the upper and lower hoses can indicate an air bubble at the water pump.
Where is the highest point in the cooling system? Can air be removed at that point?
Best
Les
Bob Kontak 11-27-2021 06:11 AM
You did drive it 25 miles. You can't do that with a non-functioning water pump or thermostat.
Bob Kontak 11-27-2021 06:22 AM
Don't think his engine has the bleeder screw.
Found the radiator cap is not a traditional pressure cap. You need to do the pressure test at the plastic tank.
I am almost certain you need a traditional radiator cap on the plastic reservoir. That could be your leak?
fastfredracing 11-27-2021 06:23 AM
Me thinks you need to find the source of the escaping coolant . This will be your huckleberry .
You know your system does not hold pressure, you also know that you are loosing coolant somewhere , you have stated that you have seen it after each no heat event .
Clean it up , fill it then be patient and let it run till you can locate where it is coming out .
Really sounds like something is up with your expansion tank . It would be the weakest link
drcoastline 11-27-2021 09:07 AM
That's what I am thinking as well. Based on Bob's recommendation I thought I would take it all that mess apart and check the hoses, tank, etc before buying a new one. Everything seemed to be in order.
The whole set up above is only $62.00 from Parts Geek so I think I am just going to get it. If for no other reason to rule it out.
drcoastline 11-27-2021 09:20 AM
Hi Bob, yes you are correct. I forgot to mention that I put the pressure cap on but then replaced it with the traditional cap.
I did do a pressure test at the tank. First with the pressure tool. It held pressure. Then yesterday when I took everything apart I tested the parts independantly. Tank, each hose.
drcoastline 11-27-2021 09:24 AM
I was thinking that as well. But looking for reinfrcement from the gang. In actuality I went 50 miles. 25 on direction 25 back. But I stopped in the middle and checked the system. Then it sat about an hour before I returned.
Scott Douglas 11-27-2021 09:55 AM
Going back to your original post, how far had you driven the car before going to get it inspected?
Did you consider it to be up to temperature when it was inspected?
drcoastline 11-27-2021 01:17 PM
Including driving to other places before going to inspection I would estimate 10-12 miles? I did stop an turn it off a few times but I think it would have been up to temp before inspection.
So per my post above I order a new expansion tank including the hoses earlier today. I needed coolant so went to my nearby Advance. While there I decide for the hell of it to get another new radiator cap (16lb) and then decide to get a new cap for the expansion tank.
When the counter guy enters the information for a cap for the expansion tank, reservior, overflow tank. Various searchs nothing matches. So he goe back to the radiator caps.
The list has three cap One 16lb with a relief handle I already have that one. A flat cap no indication of lbs. and lastly the cap I bought which looks like a standrad 16lb cap. At this time the counter guy notices on the screen the 16lb. caps indicate Reservior caps and the flat cap says radiator.
Now I am thinking the caps are backwards. I buy both caps install them, start the vehicle and I get slight pressure in the hoses within a few minutes. Not a lot but some resistance. I top off the radiator and drive back to the little hill at the beach entrance where I burp the system. No wetness at all around the expansion tank. Some condenstion behind the radiator cap on the shroud. Still mild pressure on the hoses. I opened the cap the radiator is full. I replace the radiator cap and squeezed the upper hose, I can hear air escaping around the cap. This would indicate the moisture on the shroud.
I am now starting to conclude the new radiator is defective.
Bob Kontak 11-27-2021 01:28 PM
So there is no confusion. This is the kind of cap that goes on the reservoir based on my understanding.
http://forums.pelicanparts.com/uploa...1638048490.jpg
drcoastline 11-27-2021 01:30 PM
If that is the 16lb pressure cap you would be correct. I just found a thread on an Xterra sight that conforms this.
Bob Kontak 11-27-2021 04:02 PM
Just a random pic of a radiator cap. I used the term pressure cap and traditional radiator cap.
Pic is of a traditional radiator cap. Cap on radiator must be just a sealing cap. No relief function.
Scott Douglas 11-27-2021 04:13 PM
Can you take a picture of the radiator neck for us?
drcoastline 11-27-2021 07:50 PM
Yes, the radiator has a regular cap, the tank has a relief cap. I should say now they do, they were reversed.
Yes, I will post in the morning.
drcoastline 11-28-2021 07:24 AM
This is the radiator I removed from the vehicle.
http://forums.pelicanparts.com/uploa...1638112881.JPG
drcoastline 11-28-2021 07:41 AM
New radiator. The red arrows indicate where I heard air esacpe when I squeezed the upper hose. Also where the glare is on the intake is where I have seen moisture which looked like condensation.
http://forums.pelicanparts.com/uploa...1638113656.JPG
drcoastline 11-28-2021 07:43 AM
Overflow tank
http://forums.pelicanparts.com/uploa...1638114078.JPG
Scott Douglas 11-28-2021 08:31 AM
http://forums.pelicanparts.com/uploa...1638116894.jpg
The area near your thumb looks like it hasn't had an impression made on it by the area with your arrows pointing to it.
Like I said before, I've never seen a system where the overflow tank is pressurized as part of the system. They've always just been a 'normal' cap that wouldn't hold pressure.
I'd suggest laying a straight edge on the rad opening sealing surface to see if it's flat.
drcoastline 11-28-2021 09:06 AM
I'll check it out. In the mean time from a post (not mine) on an Xterra forum that I found yesterday.
The cooling system on the X is a closed system that doesn’t normally breathe or release pressure during heating and cooling cycles. The reservoir is part of the pressurized volume and acts as both a container for the increased volume of liquid coolant as the temperature increases and a gas separator for liquid coolant. Some coolant normally flows from the top of the radiator through the reservoir to the return path to the inlet to the water pump when the engine is running, whether the thermostat is open or closed. There are baffles in the reservoir to encourage separation of any air mixed with liquid coolant if there is sufficient liquid coolant present.
The pressure relief cap on the reservoir doesn’t release pressure in the system during normal heating. This is different than more common systems that use an overflow bottle at atmospheric pressure. They are filled with liquid and the pressure relief cap opens regularly during heating and allows the coolant to flow into the overflow bottle. As the system cools and the pressure drops the coolant flows from the bottle back into the pressurized volume. These types of systems are normally filled with liquid and don’t have a gaseous volume above the liquid. The pressure build up is more a function of the liquid expanding rather than just the vapor pressure increasing as the temperature increases.
The pressure relief cap on the X has a 16 psi relief pressure. The cap should stay sealed with a 50:50 water to antifreeze mix easily past 250F. If the cap is releasing pressure at a lower pressure then both air and gaseous coolant, both water and antifreeze, are being released from the system. A small volume loss of coolant won’t affect the cooling performance of the system. But if the loss continues it will result in higher temperatures which will accelerate the coolant loss. A leak in the system will have the same effect.
Some thoughts and Observations
The cooling system is essentially a closed volume with two phases, liquid and gas. The liquid is a water and antifreeze mixture and the gas is an air and coolant vapor mix. If the system is in good repair and properly charged with coolant liquid will be circulated by the pump and gas will collect in the reservoir chamber above the liquid. The reservoir is baffled to separate gas trapped in the liquid and prevent it from flowing back to the pump.
If there isn’t adequate liquid, the gas will continue to circulate with the liquid and compromise both the cooling function to remove heat from the engine and heater core’s function to provide hot air. The reduced performance of the heater is probably the first indication that there is a problem.
From observing the system with reduced coolant it is obvious to me that air is circulating through the system, not collecting in some pocket and preventing flow. If it was collecting and preventing flow, an increase from 600 to 1200 rpm wouldn’t clear the pocket nor would slowing from 1200 to 600 rpm allow enough time for air to collect. The temperature change of air from the heater occurs to quickly for air to be collecting in the core. If the is air circulating, it is directed to the heater core from the manifold at the back of the heads before it can reach the radiator. From there it circulates back to the pump. Without adequate liquid the air will continue to circulate
If you are having to add coolant regularly there is a problem that should be corrected. The way the X cooling system is designed there should be minimal loss over time, the system is essentially sealed during normal use. If the system is leak-free and the pressure relief cap is holding the design pressure, the system shouldn’t be releasing air and vapor. The system will pressurize during heating and will de-pressurize on cooling without venting to the atmosphere.
A pressure relief cap that is either leaking at the seal or isn’t holding the design pressure will release coolant over time in the form of vapor. There may not be evidence of coolant being lost so this type of failure is harder to detect. New quality pressure relief caps aren’t that expensive and are readily available.
Scott Douglas 11-28-2021 09:34 AM
Interesting. So they're trying to make the overflow tank do double duty by acting as a reservoir of the radiator.
I wonder what would happen if you closed off the lower hose of the 'overflow' tank at the pump or where ever it goes back into the engine, and ran the hose at the rad cap down to it instead, turning it into a true overflow tank so to speak.
I really don't see how the tank can allow fluid to go back into the radiator when it cools unless it is full to the brim. Even then, how would the coolant be sucked back into the radiator once the fluid level dropped?
Scott Douglas 11-28-2021 09:40 AM
When we picked up our Alfa out in Palm Springs, we had a chance to see how a cooling system really operates. The car was running so hot it was pushing coolant out the cap of the overflow tank. We (my son and I) would stop at every watering hole along the route home and cool the radiator down by pouring water out of a bucket onto it, all the while keeping water in the overflow tank. It was a great lesson for my son as he had doubts about the water going back into the radiator, I think. That was a long drive home, especially for my wife as she was following us in the van. At least she had A/C so was comfortable. It was 114* that day and plenty hot even as the sun was going down.
drcoastline 11-28-2021 12:40 PM
Ran to Advance today to pick up the new pressure cap. While there another Xterra came in. I talked to the owner explained my situation and asked if I could look at his cooling system. When the vehicle is off the system loses pressure. When you squeeze his radiator hose his radiator makes the same hissing sound at the radiator cap.
oldE 11-28-2021 02:03 PM
Is it just me or is the rubber seal in the rad cap shown in your hand compromised around the 4 o'clock position?
Best
Les
drcoastline 11-28-2021 02:12 PM
Best
Les
It's the photo it's a little coolant on the cap. I checked the cap and flange earlier today.
mattdavis11 11-28-2021 06:09 PM
You need a cap with a deep plunger for that radiator. Over flow cap looks wrong as well.
drcoastline 11-29-2021 03:39 AM
It seems this set up is correct. Flat cap on radiator pressure cap on the over flow. I had it as you said it makes sense. This system for some reason is reversed.
This morning I ma going to go through the system of filling the radiator and over flow as described above. Then I will watch and see what happens.
drcoastline 11-29-2021 03:43 AM
Checked the cap gasket and the flange around the filler neck both appear to be in good shape. As I stated in the response to OldE I had a chance to look at anthor X and the same air sound occured on that one. So for now I am not going to blame the radiator.
Scott Douglas 11-29-2021 11:31 AM
I know I'm not the sharpest tool in the shed, but I just can't wrap my head around the logic of how this system is supposed to work. I'm out of ideas on how to fix your problem other than drive the car a lot longer before going to be tested. Only way I know of to get it hotter short of putting some cardboard in front of the radiator to cut down on it's ability to cool.
Ayles 11-29-2021 11:45 AM
Maybe going back to basics here, but I was able to get all the air out of my Xterras cooling system by using a funnel designed to help burp the system.
I had tried doing it on an incline and couldn't get that to work.
https://www.amazon.com/gp/product/B00A6AS6LY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
drcoastline 11-29-2021 12:46 PM
No one I know has been able to wrap their heads around this system so you are not alone.
Thanks Ayles, I have used that method as well as the hill and did them simulataneously
Bob Kontak 11-29-2021 12:47 PM
I got it to work with a 2010 focus sideways mounted NA 4cyl. Car ramps. 3500 RPM for 30 seconds. Shut it off for 60 seconds and top off reservoir. Restart. Repeat. Took me three times and heater was smoking hot.
The high RPM's must not give the air a chance to settle into higher cavities. It just sweeps it out of the block and then it goes to the highest point.
I'm not saying it will work on the XTerra. I'm just sayin'.
I say time for another mini trip. Fingers crossed.
drcoastline 11-29-2021 12:50 PM
All that said I think we figured it out fellas. As I said I bought new caps put them in the order per the post I showed above, pressure cap on tank, flat cap on radiator. Checked fluid levels per the recommendation in the post as well.
Took it for a ride today to go pick up a few things. Wala the check engine light went out by it's self. Pulled over kept the engine running checked the hoses hard as a rock. No indication of fluid loss.
I will drive it some more and keep an eye on it.
Thank you to everyone that posted made a coment and suggestions on what to look for, I greatly appreciate it.
Great group of people here lending a hand.
Thanks again.
drcoastline 11-29-2021 12:53 PM
The last two times I used your method, it may have contributted? Don't know for sure but thank you for the suggestion.
I used your method, the hill and the funnel all at one time. I figured I would over whelm the system burp methods.
Bob Kontak 11-29-2021 12:53 PM
Good job! Outstanding!
Now you need to find that poor guy at the car parts store and fill him in.
