That's great news that you got it sorted!
It goes back into the engine through the other tube when things cool. |
I'd sure like to see a cross section of that overflow tank to see how they 'separate' the fluid from the vapors. Glad you got it sorted dr. Keep us posted if things change. |
I wonder if the bean counters eliminated a burp plug to save a few bucks.
Success!
Good man. Lots of heat for the cold weather. Best Les |
Seeing the tear on the seal on the radiator cap (the wrong one) I'd replace it, but it should be put it in the correct location, at the very least. I don't know much about Xterras, but I sell radiators all day long.;) |
Norally you would not get an argument out of me. For some reason Nissan designed this system backwards. No tears in nay of the caps and I have two brand new ones installed. Can you get a heater core for a 1959 Edsel Corsair? |
I can't, but vintage air might.
https://www.vintageair.com/2021%20Vintage%20Air%20Catalog.pdf Glad you can enjoy the Xterra again. I've seen weird things, reversed impellers, bad T stats, broken T-stat, installed backwards T-stats, but I've never seen anything like yours. It was not intended, for only your cooling system, to work that way. |
I was at Pull-A-Part today and ran into a 2004 XTerra. Was thinking maybe I could eyeball this system.
Sigh........... http://forums.pelicanparts.com/uploa...1638303994.jpg |
Got up this morning went to my guy for inspection passed no problem then I drove to Philadelphia 80 miles on dierction, did a few things and returned. No issues. I'm pretty confident now guys we fixed it. I can't thank you all enough http://forums.pelicanparts.com/support/smileys/wat6.gif |
| All times are GMT -8. The time now is 10:14 AM. |
