Computer question...
Does this show that I have unwanted connections happening to my computer?http://forums.pelicanparts.com/uploa...1639707425.JPG
No
^^^^ What he said....
Every page you visit could be dozens upon dozens (or even hundreds) of objects or IP connections... those are just one flavor .... TCP. |
THANK YOU!
Here's what is going on. We got a new printer. Canon TR8620. I was trying to download the driver's for it and got a 'Fatal Error' message. Chatted with help and they had a tech call on the phone. He tried to convince me that all those 'current connections' were 'bad guys' trying to do 'bad stuff'. I've finally got the printer working. User error on my part as my wife has two computers she uses and I was trying to get the one that didn't have the printer plugged into it to setup the printer. The one the printer is hooked up to isn't connected to the internet so even though I got the install exe file into it, it couldn't download the driver. Switched everything up and it now works. Why's it gotta be so hard? I know a lot of it has/had to do with my setup here for her two computers. Not sure how I'll get the printer working on the old 'isolated' computer now, but that'll be tomorrows problem. |
Take any open page including this one.
Right click in a dead spot and look for then select Inspect. Dev tools panel will pop up. Along the top one of the tabs should be Network, select it. Refresh the open page. Every entry is a TCP request. I get 86 for this page alone. How many pages do you have open? |
LOL, commented code for Pelican pages.
Commented code is there for developers. They are notes that don't render to the page but they help the devs know the reason things were done the way they were or why something is there. http://forums.pelicanparts.com/uploa...1639712560.png |
http://forums.pelicanparts.com/uploa...1639712676.JPG
This is what I got when I right clicked without being logged in. |
I see, I just did it again and it says 87 requests.
Not sure what command you used to get the report but it's likely a running total and not necessarily a real time snapshot |
netstat -s
for those who wanna play with their 'puter. |
Tcp: 19317 active connection openings 0 passive connection openings 146 failed connection attempts 5993 connection resets received 18 connections established 5334102 segments received 3299000 segments sent out 5224 segments retransmitted 398 bad segments received 6248 resets sent |
If yer having an issue with TCP connects you might just be short on sockets....
It will be the 10mm ones gone missing :D I wuz a systems/network geek .... ancient history now. T-Rex ;) |
Here's what my connections look like with two browser tabs in Firefox open on Pelican and one in Chrome open on my work email. Note that Windows has a similar netstat command but I'm unsure as to options to show only IPv4/v6 stuff (no Unix sockets etc) and what process id they are associated with Note that I've got a ssh server, web server, mysql server, print daemon and such listening but that is normal and they can only be connected to from the local machine. Quote:
These days, pretty much all PCs (Win, Mac, *nix) are going to have lots and lots of connections. THere are usually a slew background processes on and listening or probing your local network for things that they can talk to. I used to find the list of services that I could shutdown as it 1 makes your machine safer and 2 makes your machine cleaner/faster. |
Not sure what NAT or ports have to do with missing 10mm socket jokes .... probably lack of Java :D.
Doubtful any of you geeks can even peek inside a TCP stack like I did for years... certainly not on "toy computers" that's for sure..... idAts ;) |
So last night I started to get worried when this guy I'd given remote permission to started talking about needing a 'level 4 or 5' technician to come and install something to figure it all out. This is what I saw when I finally called 'ENOUGH' and shut him down...http://forums.pelicanparts.com/uploa...1639753506.JPG
I think I know enough to know that installing a printer driver should not be that hard, especially when we had the previous generation of the same printer hooked up and running fine without any help needed. |
They poke around, find your porn stash, capture your browsing history, then blackmail you by threatening to send to your wife. |
Are you serious, is that a real screencap? I don't think "install advance ip security" is going to do anything other than throw an error. |
The way I check who is logged into my PC is to start "Task Manager" then click on "Users" and there should just be YOU. That tells you who is actually logged into your machine and you can look at what "Processes" are being run.
An even better way to see what is happening you can start your application for your router such as the ASUS RT-AC3200 I use down stream of my U-Verse box from AT&T. There should only be connections that you allow to connect such as a ROKU or Visio or a "smart TV set" John |
| All times are GMT -8. The time now is 04:50 AM. |
