No way that is 4-speed 930 gearbox. Way too tight between gears. "winding out" 3:rd gear in 930 is Warp speed.
My guess is some sort of mashup with 915 gearbox. 915 is not strong enough to survive 930 torque without mods (billet sideplate, steel intermediate wall). Also, its shifter is quite sloppy, and even sloppier when shole gearbox is loaded with twice torque than original. He either stripped gears or shifted into what he thought was 4:th (but tranny distorted shifter into 2:nd). |
I think it's a '76 911.
https://wheelwell.com/jayson-glanville Quote:
Yeah, I’ve seen 76 and I’ve seen 79. It’s not a 76 dash in that thing, but the car could be a complete Frankenstein. The door panels are not from an SC…
Take too long finding the gear, and the mounts relax enough for the gate to move more than you might believe likely - like the width of a shift plane over. Then the stage is set for bad things to happen. I note WEVO engine mounts - but no mention of trans mount. I run WEVO for both (blue on motor, black on trans); immediately/hugely obvious how much better controlled/much less weight moving around out back there is. I've done a 4/1 shift instead of the intended 4/3 on a 930 with a very sloppy 915 and stock motor/trans mounts. Even without fully engaging clutch (eg zero top end damage), dropping a rod bolt was $$pendy. Generally, would not recommend - although converting a running motor into a core is the perfect excuse to make it better... |
Play this game long enough and your day will come. It's inevitable.
The timing on my having caught this thread is incredible. I just had a similar experience. Pulling away from a stop, accelerating at a pretty mild rate, I heard (and felt through the shifter) a loud "bang" as I shifted into second, followed by the loudest "card in the spokes" "braaaap" sound imaginable. I stabbed the clutch in, pulled it into neutral, and did a pretty good verbal imitation of this poor guy. Except in my case, it was not a missed gear, and the motor kept running just fine. And once coasting in neutral, the noise went away... So, how 'bout third? Let's try it... sounds fine. Fourth? No problem. Fifth? Sounds normal... So I drove home, about 50 miles, by skipping second. This was the Sunday before Christmas. My younger son helped me drop the motor that Tuesday, and I split the tranny off and ran it up to my good friend John Walker. He had it repaired by Thursday, I retrieved it on Monday, and my other son and I had it back together a couple of days later. Here's what John found: http://forums.pelicanparts.com/uploa...1641681599.jpg That's second gear. Broke two teeth clean off. It simply fatigued out, after 50 years. Granted, I'm twisting that poor old 915 harder than Porsche deemed appropriate, so these things can happen. Perhaps this is what happened to poor Jayson, and it wasn't operator error after all. |
http://forums.pelicanparts.com/uploa...1641684353.jpg Driving to work, not even trying - I'd always babied 2nd too... |
Yikes - that's that turbo powa for you. Mine actually has a third tooth ready to fail, cracked about halfway through. Weird. Why second gear?
Regarding the turbo pooowwwaaahh 'v' a 915, Matt Monson posted a side-by-side pic comparing the gears in the 915 to those in a 930 box and the primary difference is in the width, or thickness of them - 930 gears are much beefier.
I have missed a shift but so far I always catch it before I released the clutch.
Been lucky never hurt anything. <iframe width="560" height="315" src="https://www.youtube.com/embed/8bFqXyzAQgg" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
http://forums.pelicanparts.com/uploa...1641690395.jpg |
But it was awesome at PIR, coz you didn't drop to 1st for the sharp right hairpin, and would hold boost right up to the braking point for the sharp left without over-revving... |
My 4th -> 1st money shift (about 85MPH, by the time I let the clutch partially out) - still span well over 7K on stock 3.3 rod bolts (no idea why PO didn't use ARP). The Porsche gods briefly allowed me the delusion that I'd dodged the bullet... 10 days later, just pottering along, rod bolt on #6 came undone/bearing span, oil pump filled up with ally swarf and tensioners collapsed... But no top-end damage, other than minor scuffing on #6 skirt/bore. |
Reminds me of that thread "has anyone ever blown a tranny?"
That thread went downhill really quickly,.... |
i'm confused.. short stroking AND turbo'ing an engine? why?
short stroking is good to make it a revvy engine.. But then boosting it?? on such an old design? with a 915 tranny??? He was going to blow that thing up one way or another.. |
| All times are GMT -8. The time now is 07:08 PM. |
