-   -   When are lawn tractor tires bad (http://forums.pelicanparts.com/off-topic-discussions/1115623-when-lawn-tractor-tires-bad.html)
masraum 03-27-2022 09:03 AM
We've got a zero turn that's about 4 years old. It's not uncommon for the back tires to spin which is a pain when trying to maneuver. Is that normal or an indication that they are old and need to be replaced?
Dpmulvan 03-27-2022 09:11 AM
Zero turns will spin the tires easily if proper turning isn’t used and will also rip up grass. My zero turn is 4 or 5 years old and tires are fine and that’s cutting about 3 acres per cut. Try smoothing out your turns.
Dpmulvan 03-27-2022 09:15 AM
https://youtu.be/iClPprJ7Olg This might help.
Seahawk 03-27-2022 09:19 AM
Spinning is a factor of the tread profile on a zero turn. I have a large Kubota zero turn that, in certain conditions, spins rear tires like a DJ spins records. The dealer recommended against a more aggressive tread profile.
I have learned to pivot less aggressively on specific lawn conditions...may not be your problem, but it was mine. Much less spin.
I love zero turns! Mine got the pre-season check-out yesterday and will get out next week.
I have some smaller MF tractors I bought twenty years ago that still have their original tires.
masraum 03-27-2022 09:25 AM
OK. I've kind of assumed it was just the nature of things, but wanted to confirm. And this mostly happens in odd/unusual circumstances, not on flat, level ground when doing normal mowing.
And yes, ours has the "lawn friendly" tires.
stevej37 03-27-2022 09:30 AM
Load them?
<iframe width="560" height="315" src="https://www.youtube.com/embed/GjaO0dA0MIw" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rfuerst911sc 03-27-2022 10:48 AM
When you do need tires consider ATV tires . You can get more aggressive tread pattern without going crazy . Then load them with windshield washer fluid you will be good to go. You still have to maneuver smartly but tread plus weight is the way to go .
greglepore 03-29-2022 04:44 AM
This. And if the grass is the least bit wet...
Also climbing-I have a steep area next to the house that stays damp in the shade, gotta ease up the over the top or I can get a little spin in the combined turn/climb, but you can creep without slowing the deck down, which is the beauty of a zt.
Fast Freddy 944 03-29-2022 08:31 AM
Id purchase some new ones, you will get the vehicle running like new with fresh sneekers.
masraum 03-29-2022 08:41 AM
I'm considering going with some of the "no-air" fronts. I guess they are normal tires that have been filled with foam. I got some flats, and converted to tubes, but I'm still getting flats.
The rears seem OK, so I'll probably leave those for now.
