-   -   DHL plane splits in emergency landing (http://forums.pelicanparts.com/off-topic-discussions/1116457-dhl-plane-splits-emergency-landing.html)
pwd72s 04-08-2022 12:11 PM
Originally Posted by URY914 (Post 11659561)
That will take more than duct tape to fix. ;)
An awesome set of TV repairman tools should suffice.:rolleyes:
masraum 04-08-2022 12:17 PM
Originally Posted by Noah930 (Post 11659560)
Maybe they could use some of those boat stands, if they can figure out where to rent them.
LOL!
Yep, duct tape AND JB Weld!
URY914 04-08-2022 12:28 PM
Originally Posted by masraum (Post 11659569)
LOL!
Flex Seal, Gorilla Glue and tie wire should fix her up.
It should be back in the air in a week or so.
pavulon 04-08-2022 01:59 PM
Planes and coffee punks are dangerous.
hcoles 04-08-2022 02:05 PM
Looks like they knew there was a potential issue. Note emergency vehicles all lined up with their lights on.
cstreit 04-08-2022 02:16 PM
Originally Posted by herr_oberst (Post 11659264)
....casually lighting a cigarette.....but not great tires.
Just came here to say this....
911/914gary 04-08-2022 02:52 PM
https://youtu.be/qPk23hPooKY
Don't know if I linked this correctly.
Juan Browne's "blancolirio" channel on YouTube has a good initial look of this event. Juan is an experienced 757 pilot.
Jeff Higgins 04-08-2022 03:27 PM
That may not be as bad as it looks. The fuselage separated at what we call a "join ring" between two major sections. The sketch below shows where these sections go together on most traditional aluminum commercial aircraft. I'm not familiar with 757 specific body section numbers, but if that were a twin aisle aircraft like I used to fly around and fix, the section numbers would be "41 section" for the cockpit, "42 section" from the back of the cockpit to the leading edge, "44 section" from leading to trailing edge (shown in blue), "46 section" from trailing edge to empennage, and "48 section" holding the empennage.
http://forums.pelicanparts.com/uploa...1649456198.gif
So, this thing separated between the 44 and 46 sections, right on the join ring. Not surprising with it side loaded and bouncing like that. And, believe it or not, entirely repairable. Just depends on the value of the aircraft, cost of repair, and the insurance company. Just like your car.
One factor that does not come into play with your car, however, is availability of a replacement, and schedule commitments. Airlines will often pay the difference between the value assigned by their insurance carrier just to get it back in the air to meet those commitments. Maybe not at this time, with lots of airplanes parked, which may decide its fate. It is, however, entirely repairable from a purely mechanical perspective.
rattlsnak 04-08-2022 03:42 PM
They lost the left hydraulics after takeoff, went into holding, ran the checklist and returned to land. They had no left reverser and no ABS and no nose wheel steering, among other things.. At most any other airport they would have been fine but this one had a ditch just off the side of the taxiway and they slid down in it..
spuggy 04-08-2022 04:48 PM
any landing you can walk away from is good at that point
I've heard it as "anything you walk away from is a landing. A good landing is when you get to use the aircraft again"..
Jeff Alton 04-08-2022 09:04 PM
Though I can't say for sure, likely an overweight landing if they had recently departed.
Cheers
berettafan 04-09-2022 05:12 AM
Don't they have a rear door for taking the packages out?
Could we get a meme with Tom Hanks holding a stop watch superimposed?
greglepore 04-09-2022 05:16 AM
Question-if they lost left hydraulics, would it have been dangerous/difficult to hold and dump fuel-its costa rica, could get out over water easily, and it seems they circled to run their checklists.
2.7RS 04-09-2022 08:26 AM
Without brakes could you've gone to Mexico City or even Houston for a longer flatter runway?
Is that possible?
Steve Carlton 04-09-2022 03:16 PM
What's with a ditch alongside the runway?
pavulon 04-09-2022 03:35 PM
Costa Rica = rain runoff management?
Brown747 04-10-2022 09:13 AM
The 757 like the 737 is not capable of jettisoning fuel. The max landing weight is close to max takeoff weight.
https://avherald.com/h?article=4f719c2d&opt=0
speeder 04-10-2022 09:22 AM
I hope that the next owner looks at the PlaneFax on that SOB! :eek:
Even if it could be riveted back together, I'm picturing a collection of wires and hydraulic lines severed that makes a BMW e38 look like a Model T. Endless CELs for the next owner. PASS. :cool:
Steve Carlton 04-10-2022 11:35 AM
As Garp would say, it’s been pre-disastered.
<iframe width="560" height="315" src="https://www.youtube.com/embed/GTqz4duPdYQ" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
LEAKYSEALS951 04-10-2022 11:57 AM
Can I reset the error codes at home or do I have to take it to a dealership?
http://forums.pelicanparts.com/uploa...1649616846.png
