What Is This Thing Called?
For the life me I cannot think of what these are called…those articulating, “swing-arm” clamps which are threaded on one end - with this threaded end fitted with a thumb screw…so when this threaded end is swung into a “receiver plate,” the thumbscrew is then tightened until the appropriate (desired) locking force is achieved. Anyone?
Are you describing Kant Twist clamps?
Nope (but thanks!).
The receiver plate features a v or u shaped open end, into which the threaded shaft with thumbnut is swung, then the thumbnut tightened against the bottom flange of the receiver plate. Hmmm...maybe I'll draw a picture and post it. |
Here it is! I knew I had something around someplace with this type of locking mechanism…here in the form of my old Leitz tripod leg-clamp accessory:
http://forums.pelicanparts.com/uploa...1650809572.jpg http://forums.pelicanparts.com/uploa...1650809620.jpg But what I need is something which operates on this principle, to replace a “fixed adjustment” hook and eye scenario. Here is my application...for our cute/lovable (and sometimes naughty) rescue-up, Lena: http://forums.pelicanparts.com/uploa...1650809686.jpg I have crafted, from plywood, foam, and faux leather, a doggie seat, which fits into the otherwise rather uncomfortable rear seat-wells of my 944: http://forums.pelicanparts.com/uploa...1650809721.jpg The doggie seat sets upon two carefully shaped plywood panels, each affixed via. existing seatbelt bolts. Currently, the seat is held down with two hook and eye locks - which to work effectively need to be adjusted exactly, but the adjustment of the whole “system” tends to deviate over time, and it would be great if I could tighten things down a bit more. Here’s the kicker: yes, I could simply install angle brackets to make this more solid…but I like the idea of being able to quickly unclip/remove the doggie seat, thus the need for a mechanism which allows such easy removal, and also allows for some adjustment to clamping force. At any rate…any ideas? Thanks! |
How about this or a couple of Lindells My Pillows?
http://forums.pelicanparts.com/uploa...1650818155.jpg |
I think that is called a split block clamp.
For the pup, why didn't you just fold down the rear seat backs? Best Les |
http://forums.pelicanparts.com/uploa...1650848489.jpg
I use this. It goes from truck to car. He's very comfortable in it like a crate. Holds him in place too but he's never ridden in the 911. He doesn't like getting tossed around violently |
| All times are GMT -8. The time now is 08:12 PM. |
