Brew Master
Wifi 6 mesh network suggestions
I've always been a bit disappointed with my wifi coverage. Buying the Blink outdoor camera system sent me down another rabbit hole... upgrading my wifi.
I have 100mbps fiber optic service. My current blend of ISP dual band modem/router in the basement hardwired to a TP link dual band router on the first floor set as an access point and a wired dual band router setup as an access point out in my barn does the job but my signal in my garage and out on my patio is lacking which makes me think the new camera system might not be able to get the signal it needs. My kids use the 5g for streaming. I could add a range extender or another router/AP but I'm thinking moving to tri-band might be nice since several of my firesticks have 6ghz capability. My main issue is that I never ran a cable to my shop. My current system will reach the outside of the shop with about 1 bar but it won't penetrate the walls of my fortress of solitude. I'm thinking I can add a wired outdoor range extender to my barn AP with a repeater in my shop and that would help with my outdoor coverage. The reason I'm thinking wired is that my barn has metal siding so the signal doesn't extend into my back yard even though it is by far the closest AP. My thought is, with a new mesh I could have two or maybe three wired AP's with two or three wireless repeaters and have the coverage I need. BTW, I'm not really a "tech nerd" so if I have the wording wrong above I apologize. I'll try to pull up a google earth image of my place. It might help to see the situation I'm dealing with.
Nick Last edited by cabmandone; 05-04-2022 at 05:28 AM.. |
Brew Master
I have cable from the house to the barn but nothing to the shop as mentioned above. My signal from my current setup is okay in the garage but out on the back patio between the garage and barn the signal fades. I'm thinking a repeater in the garage would improve signal on the patio.
I've considered a wired outdoor range extender from the barn router to the end of the barn closest to the shop thinking this might improve signal and pierce the shop walls where i could add another repeater. I suppose something like this might help the current system and it's not very expensive. https://www.amazon.com/TP-Link-EAP110-Outdoor-V3-Installation-Controller/dp/B07CG3YRTR/ref=pd_di_sccai_cn_sccl_3_3/134-9076112-4019749?pd_rd_w=pJT3E&pf_rd_p=1ed8df3a-0df8-4988-98b9-252e4c99c568&pf_rd_r=HXQ42JEKBJYMK1APXH96&pd_rd_r=e6839a53-619c-4ed2-9190-10d503a32502&pd_rd_wg=ns0Vd&pd_rd_i=B07CG3YRTR&psc=1 I considered a directional yagi on the end of the barn pointed at the shop with a repeater in the shop. None of this would cost much to add.
Nick Last edited by cabmandone; 05-04-2022 at 05:51 AM.. |
Considered Ethernet over Powerline?
'17 Cayenne |
Brew Master
I have but the work to go wired throughout the system is more than I care to tackle. All three of the router/AP's I have are wired direct to the main modem/router ethernet. My problem is I don't have cable to the shop and the work to get it there would make a mess of things. That's why I think wireless is going to be the best path forward. I won't be using the internet in the shop for streaming. It's mostly for searches when working on cars and the occasional youtube video associated with the search results. I don't have any issues with the home setup other than it doesn't reach the patio. There I could go wired because I have a pull wire in the garage attic. I could fairly easily pull a new wire from the modem/router up to the garage attic and install an AP in the garage.
Nick |
How many electrical meters from your electrical provider do you have for your home, barn and shop do you have?
'17 Cayenne |
Brew Master
Just one meter. From the meter it goes to a 200a disconnect that feeds the house and to a 100a disconnect that feeds the shop. From the shop there is a 50a breaker that feeds the barn.
Nick |
canna change law physics
I don't think a mesh system will work over those distances. Unless you connect a hardwire to the mesh routers. Trenching a 1/2" flexible conduit for the cables will not be too bad.
Trench house to barn, then barn to shop. Connect house to barn from the router, then connect barn to shop from a port on that router.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
EoP is worth a try. I am using THIS. I am a retired 25 year IT Systems Engineer, and this was recommended to me by a client with a setup pretty much as you describe yours. If it doesn't work, just send it back to Amazon.
A key setup point: The node can share a socket but not a plug. Also, the cable from your network should be directly from your router, not an added switch. Read the directions that come with it, but basically, if the nodes see each other, you will have a circuit. Feel free to PM with questions.
'17 Cayenne |
Brew Master
Nick |
Brew Master
https://www.amazon.com/Wifi-Extender-Booster-Wireless-Repeater-dp-B08RHD97QY/dp/B08RHD97QY/ref=dp_ob_title_ce
Nick |
Administrator
A new mesh system would probably be enough to suit your needs. I've been doing a lot of research and it still seems like netgear has a great reputation in the market. I'd look into thier "Orbi" product line
They offer a couple kits for 7,500ft+ -Matt Last edited by Matt at Pelican Parts; 05-04-2022 at 08:17 AM.. |
Brew Master
Nick |
Been here a while
I've got the TP link system and it has been fantastic, great speed, very reliable, easy to setup.
looking for 1972 911t motor XR584, S/N 6121622 |
Brew Master
Are you using the range extenders I posted a link to above?
Nick |
Been here a while
no sir, the TP Link Deco system, WIfi6, 4000 SQ/ft home, meandering, stone exterior walls, thick lathe and plaster walls, great coverage.
https://www.amazon.com/Mesh-Wifi-6-Router-System/dp/B085Z35GY6/ref=sr_1_3?keywords=tp+link+deco+mesh+wifi+system&qid=1651681164&sprefix=tp+link%2Caps%2C83&sr=8-3
WiFi-6 is no better than WiFi-5 unless the connecting devices are WiF-i6 also.
'17 Cayenne |
Brew Master
I'm leaning towards keeping my Tp Link router and extending that network with the range extenders I linked above. I might pull some cable to the garage and connect one as an AP but I'm going to see how it works as a repeater first.
Nick |
I have a similar situation at one house. I am using these Ubiquity Nanobeams to beam from building to building:
airMAX NanoBeam AC then I added their Aircube access point in the out building. PoE is subject to noise on teh line or maybe split power distribution issues. Range extenders slow down transmission rates and the network. Something to consider... |
Brew Master
Questions!
1. If I'm wired from my primary modem/router to each of my routers and they're configured as access points I shouldn't see any drop in transmission speed correct? 2. If I connect the repeater/AP's I bought with cable and configure as AP's I shouldn't see a drop in transmission speed correct?
Nick |
Brew Master
I bought the Tp link range extenders. Now I'm waiting for my old galaxy S5 to charge because none of apple wifi analyzer apps I've found have been very user friendly. I downloaded wifi analyzer from the google play store and checked wifi signal strength in the house on both the TP link router on the first floor and the ISP modem/router in the basement. I'm going to do a few different tests in a few locations and determine where to put a range extender and which router I'm going to connect it to. I'll start in my garage and move out to my patio.
Nick |
