-   -   Need to replace edger blade (http://forums.pelicanparts.com/off-topic-discussions/1122749-need-replace-edger-blade.html)
Por_sha911 07-13-2022 03:06 PM
Troy-Bilt / MTD gas edger with a 9" metal blade. Works great but time to replace the blade.
The edger came with a solid blade but now the replacements look like this
http://forums.pelicanparts.com/uploa...1657749904.jpg
I found this:
http://forums.pelicanparts.com/uploa...1657749933.jpg
Has anyone used this 'tri-star' blade? Is it better?
MBAtarga 07-13-2022 03:37 PM
Never tried a 3 blade. I'd expect it has more mass than the 2 blade - might cause "quicker" bearing wear due to that?
cabmandone 07-13-2022 03:57 PM
I would think that second one would require a bit more power due to the third edge causing more resistance
Por_sha911 07-13-2022 04:01 PM
That's a thought.
I was thinking that the extra weight and extra blades would cut faster. My concern was that the blade stops spinning if it goes into a solid object and I hear a screech like a slipping belt. I wondered if the extra weight would bog down the system and if would stop more.
It might be worth a try if someone has used one and it has proven to be more effective.
Scott Douglas 07-13-2022 04:05 PM
How many HP is your edger?
If it's 3 or above I might try the three blade, if less I would stick with the two bladed one.
All that rotating mass takes a lot to turn it at speed. My 2.5HP McLane works fine with the two blade cutter.
Por_sha911 07-13-2022 04:15 PM
It doesn't say HP
Its 29 cc 4 cycle that rotates at 6800 rpm.
I guess the extra mass may cause it to not work as well.
A930Rocket 07-13-2022 04:16 PM
Originally Posted by Por_sha911 (Post 11742448)
It doesn't say HP
Have you noticed small engines are no longer rated by horsepower but cc’s, torque or something like that?
cabmandone 07-13-2022 04:18 PM
It doesn't say HP
If the calculator I just used is correct, it's about 2.75 hp.
Edit: FWIW, I think I'd stick with the two edge blade. I had lawn trimmer that I installed a head on that had four replaceable thick "strings". If I put all four on, it was enough to cause the engine to bog down. If I just use three of the strings, it would run fine. What I'm getting at is, I think you might actually cost yourself trimming time because the blade alone might put more stress on the engine and once you start edging, it might cause more stalls.
Por_sha911 07-13-2022 05:18 PM
I think you are right.
I was hoping to boost the edger performance but as the old adage goes,
'there is no such thing as a free lunch'.
masraum 07-13-2022 05:44 PM
Or "no replacement for displacement!"
https://i.pinimg.com/originals/4e/76...a11b19478b.jpg
https://gtspeed.us/wp-content/upload...-lawnmower.jpg
cabmandone 07-13-2022 07:14 PM
Solid plan Steve! Add a CAI to that edger, a tunable carb, and a fart can. That ought to getcha over the 3hp range. And if you put a racing stripe on it, that should be good for another 1/2hp. I think Nitrous might be a bit overkill.
masraum 07-13-2022 07:17 PM
Turbo POWWAAAAA, FTW!
cabmandone 07-14-2022 04:52 AM
Might be easier to just do a LS swap and be done with it.
masraum 07-14-2022 05:32 AM
BAM! Genius!
https://i.gifer.com/3gvE.gif
