Still Doin Time
But when using the tool, it would slip off, pull out of the inner nut while removing or installing and just fell short on the actual service side. There are only two wheels that still have these, LR / RF - go figure. I don't know why but likely the time over the years as well as other numerous restorations I have done, that thought process was incomplete. I do remember @ 5-6 years ago doing something with removing the wheels again and deciding to toss the locking lug nuts / tool. But clearly only addressed 2 of the 4 wheels in the process.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Old dog....new tricks..... |
If that is the wheel stud i'm looking at, center punch it and drill it out.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Still Doin Time
Ok - after sleeping on it this is my solution: go online find an aluminum sleeve / barrel with the ID that = OD of the stud. With the OD slightly larger than base nut x 40mm long. I’ll make a paper pattern for the base nut OD and pin hole location .
I’ll transfer that to one end of the sleeve, hand drill for steel pins / pattern. Then use my dremel tool to square up the opposite end to 1/2” to use my 1/2” ratchet. Overall simplest, quickest, easiest way to do this as I’m not drilling the nut ( for now) |
Fleabit peanut monkey
It would be awesome if another pic could be posted allowing a 3D mental image of the stud and fastener to be formed.
1981 911SC Targa |
Still Doin Time
I’ll get another pic or two tonight……
I use those reverse Irwin easy outs but I can't see what I would be beating it on to.
1981 911SC Targa |
I've seen and played with those locks before. I may have a set of them at my other house, or may have tossed them. If you haven't gotten them off on Monday, I'll check when I go back there Monday night.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
So you've only got 2 wheels to deal with, and you've got a dremel tool. Just carefully grind the aluminum nut from the edge towards the stud to the point of fracturing the nut and you're done.
https://www.harborfreight.com/diamond-point-rotary-bit-set-20-pc-69653.html Or if it's a pressed in stud, use a small punch to center punch the stud, then a bigger punch and and a 3 lb. hammer to hit the stud hard, then find a nut that fits the threads of the stud and weld that to something that would fit in the end of a large slide hammer that you could use to pull the stud back towards you. By now the threads in the aluminum nut have probably been deformed and bet that aluminum nut would spin off with your fingers. I'd even put the other lug nuts back on the wheel to support the hub before hitting it the hard lick. Last edited by SCadaddle; 08-08-2022 at 06:05 AM.. |
3/4" deep hole saw and go real slow when you feel you're almost through. Sharp pointed punch to remove what's left on the stud. Done a lot this way. That was the worst lock lug ever invented.
Yes, you could do that, but before you did that I'd take a dremel with a cut off wheel to cut the stud down close to the nut. Saves a lot of time drilling the stud that is doing nothing extending past the nut.
Seen lots of wheels boogered by dremels, punches and drills.
Navin Johnson
I have a key for those wheel locks that looks like it might fit..
I had these locks on a car years ago, and removed them and tossed them in a toolbox drawer... LMK if you want to try ![]()
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Still Doin Time
That’s it! it would save me a lot of work if you’d be willing to part with that. I’m certain the pin spacing is not the same, but I could modify what doesn’t line up. PM me please - thanks!
Model Citizen
I was going to say I've rarely NOT accidentally had the dremel slip and go shooting off and gouging something I didn't want gouged despite my best intentions. I wouldn't get a dremel within 50 feet of that nice wheel. But I'm no rocket surgeon.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Banned
First one: ![]()
There are also quite a few projects that I've worked on where I was really really happy that I didn't have a dremel tool handy. Still haven't gotten one, I think if I had one I'd end up doing more harm than good with it.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Have you tried swearing at it and throwing stuff yet ?
No left turn un stoned |
Still Doin Time
No, but I'm pretty sure that thing and my ex-wife have a lot in common. Both high maintenance, both b*****he's, and both hate me to this day.
Model Citizen
