A930Rocket's Avatar
Compression or push on fittings for a oil cooler.
What’s the consensus between compression fittings and push on fittings for engines, etc. I’ve always used Aeroquip compression fittings, but I’ve seen multiple times where people use push-on/socketless fittings as well.
This will be for an oil cooler on my 330.
Thoughts?
Old 08-07-2022, 07:23 PM
I used them on my exige oil cooler lines. The factory crimped fittings are known to fail and i had no faith in the facrory recall.Long and not that interesting story but i scoured the internet for months before deciding to trust them. Been working fine for around 7 years i think.
I did put an oetiker pinch clamp on the outside of each fitting as a bit of insurance.
Old 08-07-2022, 07:50 PM
A930Rocket's Avatar
I was thinking about an Otiker clamp as well, but read today that it actually weakens the hose and shortens the lifespan. Maybe a zip tie…
One thing that was a little bit confusing was the temperature range. I read from -40 to 300* but I think that was the ambient temperature. A little more reading said 250° for air and 150* for water. So using this for an oil cooler, might not work.
I’m going to swing by a place in the morning that sells Aeroquip and makes hoses to get their thoughts.
Am I reading it right?
Old 08-07-2022, 07:55 PM
My reasoning for the clamp was it probably does weaken the od of the hose, but i figured the failure mode would be developing a leak vs poping off in the worst case.
Its a real biach to get the barbed fittings in the hose in either case and i dont think they are coming off.
Old 08-07-2022, 08:05 PM
Just looked in the garage i have a ton of the fc598 hose left over. Not sure how i got to that part number but i know i gave it many hours of consideration. You can see the clamp recommendation here as well
https://www.pegasusautoracing.com/productselection.asp?Product=3491&utm_source=google&utm_medium=cpc&utm_campaign=3491&gclid=Cj0KCQjwxb2XBhDBARIsAOjDZ36MGrqMFA38Q1v7L8u_ dau9lj4SO38U_A4oDU1tm2u7s5QNllRibvcaAg27EALw_wcB
Old 08-07-2022, 08:15 PM
LWJ LWJ is online now
A million years ago, I was in the compressed gas industry. Otiker clamps were highly thought of.
A data point.
Old 08-07-2022, 09:25 PM
A930Rocket's Avatar
Push on hoses and fittings are on order and I’m going to pick up the Otiker clamps.
Thanks guys.
Old 08-08-2022, 07:23 AM
