But yes, if this is a somewhat "always there" install, you'll want to make sure you have drainage arranged. |
old a/c units used f-22 a CFC as a working gas
then they used 410 a different gas the new units use ISO-butain like propane a flammable gas as the working refrigeration gas many claim the portable units as pictured do NOT out put as well as the wall units do a 16x 30 ft room needs far more then 14 k btu and the newer units do drain by the expelled air no tube needed ever in s fla |
Running over 2 weeks now and condensate tank remains empty. Unlike a dehumidifier the ac vents to outside. Device attempts to carry condensate out the vent tube. Instructions cryptically claim tank will need to be emptied under ‘some conditions’, probably some asymptotic behavior involving the outside vapor pressure. Weve had what feels like ‘high humidity’ but its not what would be called humidy anywhere else. |
A portable unit inside is basically a fan with an open window. Remind them of the definition of personal vs common areas and right to quiet enjoyment. I prefer that style. It's less likely to damage the window frame. I had to build a platform/ledge for a tenant because the plastic windows with a ridge would break otherwise. |
I lived in El Paso for a couple of years. They have really migrated to A/C from swamp coolers which were the rage forever. You can really tell which buildings have each system. Both are cool/cold but the swamp cooled buildings have a certain humidity inside and you end up feeling sticky. |
Will do.
It’s interesting in reading one of the reviews at Amazon, someone mentioned having the AC unit sit for 24 to 48 hours before using it. What’s going on with that? |
^^^ some say the same thing about moving fridges and freezers.
I think it might have been true 50 years ago. I doubt it applies now. |
the compressor was a piston pump that ran in oil
if shipped on it's side the oil can flow out of the compressor and in to the lines leaving a dry pump at start up letting it sit allow the oil to flow back into the pump modern compressors use a scroll style pump still needs oil but drains back faster not having a piston in the way also my propane refrigerator had no pump it worked by boiling the gas by heat from a flame and the gas went thru a tube of liquid gas that was need to be in place wakes/wave rocking the boat moved the liquid out of place and the unit had to be placed inverted to restore the liquid placement about once a month or after a storm so maybe a folk memory from units before el was common ? |
I have a Whynter freestanding AC unit in my office. It cools the large room down pretty well. The exhaust duct gets warm so wrap it with some insulation so that heat doesn't get into the room.
It was scheduled for delivery tomorrow, but has now been bumped to Monday. I’ll let everybody know Tuesday how it set up and worked. Fingers crossed.
Last night I had my work apartment set on 60° and at home tonight, I have it set on 70°. Since I foot the bill at home, it’s not going any lower. I’ll raise it back up to 75° in the morning. |
I only usually use the central A/c to remove moisture. 75deg max usually.
A small unit could get overloaded. I usually only get a few years out of small A/C and dehumidifier units. Odd. Fans make everything more pleasant despite any temperature outside. |
It showed up today after all. Got it installed and turned it on a little while ago. We’ll see how it works tonight.
It’s quieter than the window unit I had. If I keep it, I need to seal up a few gaps in the window and wrap the hot duct http://forums.pelicanparts.com/uploa...1661567506.jpg |
Please keep us posted on continued observations and feedback - thanks, Rocket! :) PS - are both of those ducts for the exhaust? |
The two ducts are intake and exhaust. Being a typical guy, I assembled it without looking at the instructions 😂…. I wonder if it’s got a recirculate? |
Intake from the outside rather than the air in the house?
With a small space, which is LEED certified (sealed up tight), it will actually run out of air inside.
I'm not knowledgeable enough on HVAC to understand the physics, but I'm sure it's part of how this machine is designed to efficiently do it's cooling. One thing I read in the reviews is commentary about providing separation between the two tube outlets so the outgoing hot air does not get sucked back in through the inlet of the other tube. Some of the configurations have the tubes in vertical alignment with the exhaust above the intake so the hot air will at least tend to go upwards. Another person mentioned using a piece of wood as a divider. I really don't know if this is a legitimate issue at all. You read all kinds of stuff in these product reviews and I've learned over the years to take everything with a grain of salt. I do know this.......there have been MANY times when I was so grateful to have air conditioning I have felt it should be considered one of the "Seven Wonders of the World"........so can fully appreciate not only this thread for more information but more importantly that our fellow Pelican is able to get some relief in the face of that local semi-fascism....:D |
My old one has exhaust only. At least I think it does...the instructions are around here somewhere. |
| All times are GMT -8. The time now is 11:02 AM. |
