Point of use water filters
I just found out that one of our town wells has a chemical contaminant. There's no evidence that it has migrated to my part of town but it is one big water table and the cost to test my private well is >$500. So, I'm thinking a top o' the line water filter under my kitchen sink is a way to go.
Any users here? Reco's? |
local county guys do not do tests FREE ?
OR CHEAP ON LINE MAIL AWAY TESTS ? WE HAD A FILTER PITCHER FOR DRINKING WATER WHY TREAT THE SHOWER OR FLUSHING WATER |
Years ago we had an "Everpure PBS-400". It was designed for "sinks and wet bars." I put it on our kitchen sink (cold side only). It did reduce the flow rate a little, but still plenty to be useable. We had city water, but didn't like it.
They don't appear to make the PBS-400 any more, but they still make filters for it. I suspect this is the new version of the same thing (under sink filter). The filter is rated for 3000 gallons or 1 year. This is designed for 2.2gal/min flow rate. https://www.pentair.com/en-us/water-softening-filtration/products/undersink-countertop-filtration-systems/freshpoint-easy-flow-undercounter-filtration-system.4005450.html They have a commercial thing that looks more like what we had and is designed for "fountains". It's designed for a 1.67gpm flow rate, so quite a bit less than the one above. I assume it may filter a bit more, but be more irritating when you're trying to fill a huge pot with water or wash dishes. It's rated for 9,000 gallons. https://www.pentair.com/en-us/products/business-industry/filters/filtration-systems/qc7i_single-mc2_filtration_system.html |
Most housings are similar.
It really comes down to the filter media. Get a housing that has plenty of media options. |
For a countertop dispenser, check out Lifestraw. Or go big with an undersink reverse osmosis unit. |
What type of contaminant?
I would look at nitrates level too. Gov level is very generous. |
I found a fee of about 500 for a complete top of the line test of my well to be worth the peace of mind. I was very relieved to see the results showed I had a great water supply. The only issue I have is hard water, which I deal with by using a particle filter, then a water softener. Even though it is unnecessary, I use a Brita filter pitcher, but mainly due to the fact I like to have cold water in the fridge. I did go to the water company at one time to inquire about hooking up to the public water supply, and the representative told me I was probably better off with my well than using their water. |
You need to know the contaminate to properly filter.
NJ well testing act has driven up the cost of testing(for a real estate transfer), which used to be free from the local county, to about $1000. However, you don't need certified testing at this point, and a re-test for a single item is much cheaper. I would test for your concern contaminate, you may not have a problem. In any event, I wouldn't use the company in Flanders, with the fancy web site...... Your town or county may have resources for local homeowners. We happened to grow up in this neighborhood, moved out in the late 70's, found out later that our well was probably contaminated with carbon tetrachloride by a neighbor. https://www.nj.gov/dep/srp/community/sites/pi/g000011456.htm In the case above, the contamination travelled about a half mile. |
In case anyone is interested...It is in fact PFAS in my aquifer so I had a carbon/RO unit installed under the kitchen sink. This stuff is everywhere.
REverse Osmosis (note I do not know if it will remove your contaminant specifically) plus carbon.
We have an undersink model that we use for all drinking water and the fridge. Amazon - called a "Waterdrop" iirc. Much easier to maintain and install than tank based systems. |
As I have not studied Chemistry is decades, please don't consider me an expert. But isn't PFAS relatively inert? If so, a carbon filter won't bond with it. My understanding is that Carbon isn't a filter but rather a chemical "magnet" that connects with impurities and keeps them out of down stream.
Anybody? |
Mine is also in the basement so more head pressure means less flow - but I prefer it there. Ive had this system for 6 months and am happy with it. We're on a well that comes out of a limestone aquifer. Water is great. http://forums.pelicanparts.com/uploa...1683059671.jpg |
https://www.epa.gov/sciencematters/reducing-pfas-drinking-water-treatment-technologies Quote:
Nice clarification Rockfan! Not a bonding but rather absorbing. Thanks!
| All times are GMT -8. The time now is 01:38 PM. |
