-   -   Help with Wiring up a DC motor (http://forums.pelicanparts.com/off-topic-discussions/1126550-help-wiring-up-dc-motor.html)
Harpo 09-17-2022 10:38 AM
I purchased a used Baldor CD 3475 DC motor to be used with a KB controls KBMD controller. The DC motor has 6 wires (not 3 that I'm used to) A1, A2, F1, F2, F3, F4.
I will be attaching the A1 and A2 to the A+ and A- depending on CCW or CW of the motor shaft. However, I'm confused by the remaining 4 wires F1 etc. According to the wiring diagram on the motor there are two wiring options Hi or low voltage. Which one do I want for a 110v line input? Ultimately, I need a F+ and F- for the controller.
Davidhttp://forums.pelicanparts.com/uploa...1663436248.jpg
carambola 09-17-2022 01:09 PM
110V is considered low voltage
Wire nut the odds and evens in two separate bundles
908/930 09-17-2022 01:36 PM
From the looks of it the controller is flexible can do full and half voltage out 100/50 so you can just pick one.
Harpo 09-18-2022 08:11 AM
This is what I have come up with. Can someone please confirm?
http://forums.pelicanparts.com/uploa...1663513782.png
Harpo 09-18-2022 08:26 AM
I have modified the schematic to reflect clockwise direction
http://forums.pelicanparts.com/uploa...1663514709.png
908/930 09-18-2022 09:38 AM
That looks correct. What are you driving with the motor? If using it in the lower speed range you will likely need an external fan to cool the motor. I have used those drives with PMDC motors in the past, long ago, and found that I needed to make sure the output voltage was set to less than 90v or the motor would not hold a constant speed.
I was trying to find the reason for using high or low voltage for the field but could not find any explanation.
