Hmmm. I never thought about doing this. Still won't. lol
75W-90 isn't motor oil, it's for transmissions. Anyone who has ever tried to get transmission oil into a manual transmission from a one quart bottle will appreciate this innovation.
When someone comes out with motor oil in squeeze pouches I'll be on board with the snarky comments here, but so far all I've seen is a very useful solution to a very messy problem. |
You have to put a tube, (small hose), on the quart bottle tip and squeeze it in. Just did it for the MG differential, PIA.
Watched a friend use one of those pumps that you stick in the barrel and suck it up. Funny to see him swear as it runs down his arm when filing. |
I've used one of these successfully in the past. It'll depend upon the car and what you're filling how easy it is to use. I'm sure the pouch and one of these would be great. https://images.pepboys.com/fit-in/70...3100/10106.jpg |
At 15 my dad and I were changing the clutch in a chevy chevette. In the chevette, the shifter goes right into the top rear of the tranny. Since I was slimmer than dad, when it came time to pull the transmission out, I was under the car bench pressing it. I had to rotate it to get it out between me and the bottom of the car. When I rotated it, 10 year old gear oil poured out into my hair. It was disgusting. I spent about 30 mins washing my hair over and over and over again. |
Good thread Paul, not something I had every considered.
I will be shaking them up moving forward, only takes a minute and if it potentially helps that is cool, it definitely will not hurt anything. |
| All times are GMT -8. The time now is 05:11 PM. |
