A tool I wish someone would make
Lying on my back under the dash of my 356 coupe soldering wires. ARGH!!
I wish someone would make a soldering iron with a tip like spring loaded pliers that would hold the wire joint tight between the soldering tip and some non-heat transferring material (Bakelite?). My 140 watt soldering gun works great for 12 ga. wire if I trap the wire between the tip and a stick of wood where I can get some pressure on it, but out in the open air I can't get any pressure on the wire (= poor heat transfer).
You could probably fabricate something pretty easily. Take some duck bill vice grips and glue an insulator of your choice on each side. The bottom would be solid and the top would have a window opening for your iron. Clamp the wires in the device with your splice in the little window and solder them together. Bam!
It would hold your wires together securely and make it easy to get a good hot transfer. I fabricated a similar rig back when I was building a lot of 3 pin mic cables from quality components in the 80s. Once set up I could do them pretty quickly and many are still in use today.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
I have one of these which is handy for holding small wires together when soldering.
Model Citizen
Picture something like this with spring clamps instead of a solid base.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
And...here's a guy who makes a good case against soldering:
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Probably not a solution, but now I know they exist, and I need a pair.
https://smile.amazon.com/KIMISS-Soldering-Multi-Function-Automobile-Maintenance/dp/B09MM7T9BZ/ref=sr_1_2?crid=14VFFD2P94AB5&keywords=soldering+pliers&qid=1665618512&qu=eyJxc2MiOiI0LjgzIiwicXNhIjoiNC4zMCIsInFzcCI6IjQ uMTcifQ%3D%3D&sprefix=soldering+pli%2Caps%2C156&sr=8-2 |
Wow, yeah, I've used the cheap parts store crimpers and terminals for years and they suck. I don't see myself doing much crimping in the near future, but if I find myself needing to do some, I'm getting tools like he has at the end of the video and good terminals.
How about Lucas bullet connectors (I know, I know, Lucas is the Prince of Darkness..) but these things have their place. Crimp on male/female connectors. And it makes removal easy. Just a thought, no help on the soldering clamp.
I know you are not meant to solder. But I do. I've never had one come apart accidently. Then I put heat shrink over the join.
I just recently bought the crimpers he showed at the end with the connections. They work well.
I’ve also tried the connectors with the built-in solder and heat shrink. They seem to be hit or miss for the solder to melt. |
Somehow I posted twice. Still nothing constructive to ad.
How about no solder or crimp connectors? Developed for motorcycle use. https://www.posi-products.com/posilock.html
![]() http://www.motorcycle.com/blog/wp-content/uploads/2017/01/010416-How-to-splice-wires-7608.jpg
Paul 82 911SC - 3 yrs of fun (traded-in) 2011 Cayman (simply amazing, smiles for miles) Last edited by astrochex; 10-12-2022 at 05:39 PM.. |
I've used a lot of the posi-locks. So far they work great and can be taken apart without cutting wires.
Sold: 1989 3.2 coupe, 112k miles |
![]() I know ignition switch and turn signal switch on my 356C use bullet connectors but I don't think dash lights, etc. are set up with them.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
If these are good enough for the defense department contractors....where I used these 35 years ago.....
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Fleabit peanut monkey
However, I now use a mini butane torch and the heat shrink can withstand a good deal of direct flame without disintegrating. I still don't like the connectors very much, tho. Frankly, I think wdfifteen could benefit from using this torch in the under the dash scenario for conventional soldering. It does not work when pointed downward but upward it's awesome. Tiny but mighty flame. https://shop.advanceautoparts.com/p/turbo-blue-torch-blue-torch-stick-butane-lighter-w-bottle-opener-22226/12055407-p?product_channel=local&store=8740&adtype=pla&product_channel=local&store_code=8740&gclid=EAIaIQobChMI_a3Gl4Pc-gIVDQCtBh3F4QYpEAQYBCABEgJS1fD_BwE&gclsrc=aw.ds
1981 911SC Targa |
Make Bruins Great Again
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Model Citizen
Remember the movie Pineapple Express where they had a joint in the shape of a cross?
I just learned about this cool little jig. Can probably use it in tight spaces.
https://www.amainhobbies.com/protek-rc-carbon-fiber-soldering-jig-ptk-5340/p424738?gclid=Cj0KCQjwy5maBhDdARIsAMxrkw3gX6QfPAnq TO_0RT1rXcC1mgltQ7RTMCVaDZw0kKBuXjxttpCG9fkaAk1uEA Lw_wcB
1982 911 Targa, 3.0L ROW with Webers |
Did a bunch of soldering wiring repairs on my split window VW bus with a small butane torch without the soldering tip. Just the flame. I wouldn't attempt it with a typical soldering iron.
