I see you
How to attach a sub woofer
I had to replace my receiver and bought another 5.1. However, the sub woofer output is only a standard L/R RCA plug and no power outlet.
The lead coming out of the speaker (RCA RT 2870) is only a single pair (purple black). Is there a way to attach that single pair lead to the RCA terminals?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Insert Tag Line HERE.....
That’s strange.. usually the newer receivers have a separate subwoofer output lead that is the single pair lead. I would think there might be an adapter but can you post a pic of the back of your receiver and the speaker leads?
Marc |
Which model receiver is it?
I see you
back of the Sony STR DH 590
![]() The speaker lead is a simple wire pair such as you'd use in a pinch terminal.
Band.
Does your subwoofer have a built in amplifier
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I think you need an adapter like this. You would only use the top RCA jack. The bottom is if you have 2 subs.
https://www.newegg.com/p/2BY-0004-00032
I see you
It does but I don't see a power out jack for it.
I see you
Found this discussion from 2009. Nothing definitive though. https://www.hometheatershack.com/threads/help-with-using-an-rca-rt2870-subwoofer.23351/
Present: 1984 928S/Indischrot, 1994 968/Polar Silver Past: 1979 911SC Targa/Petrol Blue |
With my powered sub...I found that using the sub-out connections did not allow some dvd's to pass the bass through.
I changed my wiring to connect the sub by running wires from the front main speakers to the wire terminals on the back of the subwoofer. (eliminating the sub-out wires) Works great for all dvd's now.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
I see you
I see you
A pic of the back of my subwoofer.
I replaced the LFE in wire with wires using the speaker inputs. (which can be done either at the speaker or the amp)
Someone had to.
Its complicated. Subs usually have a choice between line level input and preamp level input, like the expensive sunfire sub above. Even the cheap ones. Yours was probably part of a set, so you don't know which. The outputs of your receiver labeled sub are preamp level.
If you power a pre level input with speaker output, you might damage the preamp in the sub if it has one. The speaker you have likely has a line level input, which means it may not produce any volume with the above adaptor-your sub out is pre level and the power would be too low. . However, if the sub input is pre level, that adaptor would work. Safest course would be to try the adaptor and if no volume, assume the sub input is line level. Bass at sub frequency is non directional, so just drive it off of one speaker channel.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Band.
Perhaps you should plug a rca cable from the subwoofer out of the receiver into the rca input of the subwoofer.you can use one or two if you like. Bless your heart
I see you
I bought a Chronos Special Edition Blu-Ray a few years back. Playing it, I immediately noticed that my sub was not working. Tried other discs...working fine.
I was upset after paying $30 for the disc and getting no bass thru my subwoofer. I looked closely at the print on the disc package and came up with a website for the production. At the website was a phone number...so I called. The guy that answered the phone asked me to email a pic of the back of my sub...which is the same pic as above. He said that the rca output on my amp can't pass the digital audio encoding on some newer discs. He said "throw that cable away and run wires from the front main speakers to the audio ins on the sub." I did that and it works great on all discs. As an interesting side note... He said he is an audio engineer and has worked for Alan Parsons and now works for R&B Films.
I see you
That implies that you're feeding the signal going into the Fronts back to the amp?
No...from the front main speakers to the powered subwoofer.
Just leave the original speaker wires on (the ones from the amp to the fronts) You will end up with double wires on the front main speakers...one pair from the amp and one pair to the sub. Amp to front main speakers to subwoofer using speaker wire
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 10-19-2022 at 04:26 PM.. |
