-   -   Gas pump nozzles not designed by men! (http://forums.pelicanparts.com/off-topic-discussions/1131350-gas-pump-nozzles-not-designed-men.html)
masraum 12-12-2022 10:12 AM
It seems like these days, when a gas pump shuts off, I can wiggle it around and shake it until my wrist is sore, but inevitably, when I pull it out of the tank, at least one drop falls from the end of the nozzle. It's reminiscent of something else that we deal with.
That's why I'm sure than men didn't design the nozzle, because if we did, we would have ensured that either no shake or a simple shake would has dislodged any drop that was clinging.
stevej37 12-12-2022 10:18 AM
When the pump kicks off...hold the trigger for about 2 seconds before pulling it out. :D
Jeff Higgins 12-12-2022 10:26 AM
Us motorcyclists have long been plagued by pump nozzles that drip. The worst are the ones that have been returned to their place on the pump, but still hold some amount of gas, ready to pour out all over our gas tanks before we even pull the handle. Premature pumpulation. That's why you'll see motorcyclists shaking it before we put it in.
flatbutt 12-12-2022 10:40 AM
I always invert the tip before putting it in. Some like it some don't.
Arizona_928 12-12-2022 10:53 AM
Diesel does this way more than gasoline!
Something Something low vapor point
matthewb0051 12-12-2022 11:02 AM
Shake shake shake
Dance Dance Dance
The last drop always goes in your pants
masraum 12-12-2022 11:04 AM
Originally Posted by matthewb0051 (Post 11871096)
Shake shake shake
Dance Dance Dance
or down your fender or on your shoe...
fintstone 12-12-2022 11:15 AM
Maybe you need to sit down to pump.
masraum 12-12-2022 12:17 PM
Originally Posted by fintstone (Post 11871117)
maybe you need to sit down to pump.
lol
fintstone 12-12-2022 02:05 PM
I don't know squat about the pump handles, but when I travel, they are really hard to use in some areas and not others. I suspect that certain states/cites require some kind of weird handles to retain fumes (climate change doncha know?) that don't work so well. An "improvement" like the low flow toilets you have to flush 3 times.
KFC911 12-12-2022 02:25 PM
^^^^ Gas cans today :(... fixin' a problem that never existed in my world. They suck bigly....
Jeff Higgins 12-12-2022 02:28 PM
Washington has, by law, these horrible compressible bellows that surround the nozzle to supposedly catch any fumes. On my '72 911, the first bend in the filler neck occurs high enough up that it is impossible to insert the nozzle and compress the bellows enough to allow it to pump (there is a shutoff on the nozzle that has to be tripped by compressing the bellows). So, I wind up having to hold and compress the bellows with one hand and the handle on the nozzle with the other.
That's a trick I had to learn while filling motorcycle tanks with these poorly thought out devices. Oh, it's entirely possible to stick the nozzle in far enough to compress its bellows, but then the nozzle is so far into the tank that it will only half fill the tank before it shuts off. So, we pull the nozzle up until the bellows are no longer compressed, compress the bellows with one hand, and squeeze the handle with the other.
I bet the gasoline spilled by folks filling older vehicles and motorcycles contribute vastly more fumes than if these bellows were not used at all. And let's not even discuss trying to fill a gas can... I've lost track of how many I've seen knocked over by some poor sap trying to compress that damn bellows down onto one, spilling its contents across the parking lot.
Arizona_928 12-12-2022 02:34 PM
Exactly. Ban the old cars. If old timers want to use them. Lets build tracks for them...;)
varmint 12-12-2022 03:24 PM
my state is exempted from the foreskin nozzles and ethanol due to the extreme weather.
the things you're complaining about were not designed by "men> they were designed by federal eunuchs.
A930Rocket 12-12-2022 07:01 PM
You should try the double back hand when you pump. Seems to get a little more out of it.
fanaudical 12-12-2022 07:39 PM
The first few posts in this thread remind me of an old Buddy Hackett joke - went looking for it on YouTube but couldn't find it...
911boost 12-12-2022 11:31 PM
My 2010 911 is like yours Jeff, the nozzle never sits in it right.
Oh and it has a tiny freaking tank, tiny.
Bill Douglas 12-12-2022 11:43 PM
Same here. I don't know about the previous persons habits regarding shaking the drops off.
HobieMarty 12-12-2022 11:44 PM
So you're sayin that you never achieve full penetration? That's a sad story. [emoji23]
Chocaholic 12-13-2022 04:29 AM
Clearly this thread is a metaphor for the aging male population and their prostate behavior. C’mon fellas, fess up.
