A small warning:
-I once changed coolant on an overheating 89 Golf. -Tested the radiator fan directly. Changed fan thermo switches. Tried out three different spec thermostats. Used all the different ways to refill the system. etc -It still overheated... -The lack of fan was probably the ECU circuit. Fan and switch were both new and good. -Eventually the heater core (a separate radiator under the dash used for heat) popped from overpressure and sprayed boiling water over the interior at the worst possible place. This was caused by an air pocket or a clogged core. https://haynes.com/en-us/tips-tutorials/why-car-heater-not-working https://www.buildpriceoption.com/car-heater-core/ |
| All times are GMT -8. The time now is 08:01 AM. |
