-   -   What to Use - Remove Burnt oil from Stainless Headers (http://forums.pelicanparts.com/off-topic-discussions/1136310-what-use-remove-burnt-oil-stainless-headers.html)
asphaltgambler 03-09-2023 06:03 PM
On my 911 build have B&B polished stainless headers / heater boxes. 1 v/c started seeping, I'll use some gum cutter to get the excess off, but what then?
Anyone run into this problem? I have different types of metal polish and a few buff wheels with my drill.
masraum 03-09-2023 06:07 PM
Barkeepers Friend?
gregpark 03-09-2023 06:36 PM
Barkeepers friend seems to work better than any other metal polish but soft scrub and bleach might be the ticket
VINMAN 03-09-2023 06:49 PM
Blue Away or Simichrome?
MAS956 03-09-2023 06:53 PM
Try the technical forum. It's a whole new motivated herd. We old bastids be crusty.
fanaudical 03-09-2023 08:03 PM
Something we use at work on brushed stainless: Simple Green with those Mr. Clean Magic Erasers - Takes some elbow grease, but doesn't scratch the stainless.
Indescikov 03-09-2023 08:15 PM
Oven cleaner
Pazuzu 03-09-2023 10:10 PM
Is there still actual crusty oil on there, or just smooth stained metal? If crusty oil, then get a scotchbright flap disk for your angle grinder and go to town, you'll get a nice brushed finish on the headers as well.
LWJ 03-09-2023 10:18 PM
That purple cleaner rinsed similar ick off my Dirtbike pipe.
asphaltgambler 03-10-2023 01:42 AM
OK, thanx
mgatepi 03-10-2023 06:42 AM
Media blast? Dry Ice? Vapor blast?
Arizona_928 03-10-2023 06:47 AM
Acetone.
Then dcm.
Iirc dcm is in oven cleaner.
HobieMarty 03-10-2023 07:07 AM
Super Clean!!!
After fixing the oil leak from the engine in our Nissan Quest I put the vehicle on my ramps and got under there with some Super Clean in a spray bottle and soaked the underside of the vehicle and the engine where I could see any oily grime wetness and buildup. I let the stuff soak for a while and then hosed it all off. It did the trick.
matthewb0051 03-10-2023 09:43 AM
peanut butter
tdw28210 03-10-2023 12:11 PM
Some dry Ice shops have some tools to work on exhaust systems. Maybe check with them?
asphaltgambler 03-11-2023 06:51 AM
Pretty sure there's no dry ice shops like that near me, but will googly that.....
