LinkBack | Thread Tools | Rate Thread |
Make Bruins Great Again
What's the difference between indoor and outdoor water based paint?
Other than the obvious...
I have an old wood porch swing that sits in the rain and is never used. Its for looks only and it doesn't have to look new. Old and shabby adds to the antique look. It hasn't been touched and the wood is so dry that the spousal unit tried spraying it with a rattle can (bless her darling heart) and you can't tell it was touched. I have some leftover white indoor water based paint and thought before I throw out the swing, why not put a coat of the indoor paint on it to see what happens? What's the worst thing that can happen? I am not a painter and really don't want to put more money into the swing. Imput welcome. Fire suit is on so go ahead and flame away.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
weekend wOrrier
^ Buy a quart of outdoor water based paint.
Paint 1/2 the swing indoor, 1/2 the swing outdoor and run an experiment. Post results here
Model Citizen
U.V. blocking additives?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Am I wasting my time?
weekend wOrrier
Only if you cannot answer your initial question.
Sure, you can slop the stuff on, but that won't answer anything. I think your question is worth more than the swing itself. In the name of science!!!This is bigger than both of us now. If you don't do it, I will, and make a youtube video, and make $10's of dollars in the process. |
Exterior paint resist fade a bit better then indoor paint. I think it has more pigment in it
I'm good with that.
weekend wOrrier
We're talking about an old swing in the corner of the lot for decoration only. Think rusty old water pump, wheel barrow or tractor as deco...
So is the indoor paint doable for a quick touch up on old dried out wood unless someone else has expertise to advise if this is a bad idea.
In another category is gloss and hardness. Exterior paints don't look that good on interiors. Some will still use a high gloss on interiors but they are just using an exterior paint for all I know. On the flip side, no one looking for longevity would use a satin egg shell finish on the exterior intended to have a soft look. There are, of course, flat paints for the exterior but they have different resins and filers. The pigments all come out of the same mixing system. You won't find a difference there. And as likely as not, you will see paints labeled "interior-exterior." |
What?
The difference is INdoor and OUTdoor. Harharhar.
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
