-   -   Freewheel removal... (http://forums.pelicanparts.com/off-topic-discussions/1142155-freewheel-removal.html)
Scott Douglas 06-23-2023 04:21 PM
Friend of mine has a broken spoke so I'm trying to fix it for him. I got the wheel torn down to the point of being ready to put the new spoke in.
Problem is, even though the spoke goes thru the hub flange opposite of the freewheel, it would appear you have to remove the freewheel so you don't bend the spoke to get it in.
I looked at the freewheel/axle and there's no apparent mechanism to get the freewheel off. There is a 'race' just inside the outer gear that has two 'holes' for a spanner to grab it but that's for the freewheel bearings. I don't think it's for removing the freewheel from the hub itself.
Help!
This is an old [EDIT], it's a Motobecane mountain bike wheel hub if that makes any difference.
I knew we should have taken the wheel with us when we went to get the new spoke.:(
john70t 06-23-2023 04:39 PM
Pics are worth 1000 words unless someone is proficient.
Scott Douglas 06-23-2023 04:41 PM
Sorry, I don't have pics. I left the wheel at my friend's house.
herr_oberst 06-23-2023 04:45 PM
You need one of these. Most likely the one in the middle judging by your description.
http://forums.pelicanparts.com/uploa...1687563893.jpg
ramonesfreak 06-23-2023 04:48 PM
It’s simple but you need the specific size freewheel tool for that brand freewheel
Watch
<iframe width="560" height="315" src="https://www.youtube.com/embed/rdQE8-ea1uw" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Scott Douglas 06-23-2023 04:49 PM
Here's a pic of the wheel I'm dealing with.
The spoke would need to come in from the far side of the near flange.
http://forums.pelicanparts.com/uploa...1687564131.JPG
In order to do that I have to remove the freewheel from the far side flange.
Scott Douglas 06-23-2023 04:52 PM
Yeah, I think another trip to the bike shop will be in order.
Zeke 06-23-2023 04:59 PM
I don't see why a gentle bend to accommodate that won't work. By the time you tighten it that has to be able to pull any wave you might not get out. Tweak it with a rubber mallet as you cinch it up. What do you have to lose? One spoke?
Scott Douglas 06-23-2023 05:03 PM
I hear you Zeke, but it's more of a bend than my ex-machinist self is willing to put into the spoke.
It's going to be hard enough with the freewheel off as the threads on the spoke have to be very straight to get thru the hole in the flange.
sc_rufctr 06-23-2023 05:06 PM
This.
john70t 06-23-2023 05:11 PM
Never run into that situation.
With the wheel off, you should be able to hook it into the hub and push it through.
This might require loosening all the other spokes and starting over from scratch..but so be it.
Do the four directions equally very carefully so no run-out or oblong until finger tight.
Then do the ones in between the same until all begin to get snug.
Then incrementally tighten all.
It takes a long time to do spokes. Not a pro at lacing but done a few.
Get comfy with a nice seat and music.
After loading something will probably shift and need more fine tuning. Small adjustments are better.
Put some blue tape to mark the start/stop of rim wobble.
otto_kretschmer 06-23-2023 05:38 PM
hope this helps
it's on an old Peugeot
<iframe width="560" height="315" src="https://www.youtube.com/embed/b5MnOl2crx8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
A long time ago I had a pair of chain whips and those were used to remove sprockets from the freewheel.
look 171 06-23-2023 06:36 PM
GEt us a pic of the other side with the wheel off, pull the skewer too. Judging from your two dimples description, it just may be the center tool from Herr's pic is needed. Tome to visit your local bike shop.
Scott Douglas 06-23-2023 07:13 PM
Thanks guys.
I have a feeling (and it's not a good one) that I'm dealing with what is shown in otto's video link.
This brings back memories of when I had to take the freewheel off my JC Higgin's 10-speed when I bent the rim. Getting that freewheel back together was a nightmare. This was when I was in Jr High so it was some time ago.
Is there a trick to keeping the 'ratcheting' pieces collapsed so you can put the freewheel back in place without fighting them too along with all those small ball bearings?
herr_oberst 06-23-2023 07:54 PM
Scott, don't overthink this. You're bike isn't an old Peugeot, its an old-ish Mtn bike using probably Shimano or Suntour (or maybe Sugino) components. Probably Shimano, and the freehub will come off with a pronged remover like the one I showed you in the picture.
Don't try and chisel it off with a big screwdriver or anything, just take it in, have the shop take the freehub off and stick the new spoke on. Pay the guy, tell your friend it's fixed and put it behind you. If you were close to my house I'd do it for free for you in a few minutes.
sc_rufctr 06-23-2023 08:13 PM
Freehubs have a lot going for them. They last forever and they're cheap.
Have you ever had to remove a stubborn Lock Ring on a Cassette? Aside from an appropriate adapter you'll also need one of these.
http://forums.pelicanparts.com/uploa...1687576295.jpg
rockfan4 06-24-2023 07:25 AM
Originally Posted by otto_kretschmer (Post 12030019)
hope this helps
This is terrible advice. He didn't remove the freewheel, he disassembled that. The only reason you would ever do that is if you were stuck in the middle of nowhere, had no access to tools, and the bicycle was your only way back to civilization.
mocha07 06-24-2023 07:57 AM
Help!
There are numerous videos on you tube covering this,step by step.
Zeke 06-24-2023 10:24 AM
Looked a little dry in there. Maybe a good thing he accessed the ball bearings. Kludge work beating on it.
otto_kretschmer 06-24-2023 10:47 AM
The video I posted is probably a different freewheel, Motobecane is a French company but that mountain bike is from the 80s or 90s.
