-   -   Detached Garage Foundation Issues.... Fix or...? (http://forums.pelicanparts.com/off-topic-discussions/1144085-detached-garage-foundation-issues-fix.html)
Arizona_928 08-01-2023 01:49 AM
Looks like I'm getting a new garage but with the back corner having significant structural issues. Is it possible to fix or just run with it?
http://forums.pelicanparts.com/uploa...1690879753.jpg
Tim Hancock 08-01-2023 03:31 AM
I can't tell you exactly how to fix it but if it were me, I would likely buy some block and a bag of mortar and patch it up. way less time/money to fix some block vs tearing down and rebuilding an otherwise fine building.
This of course assuming the majority of the rest of the building is still solid.
stomachmonkey 08-01-2023 05:34 AM
What is that pipe coming in from the left?
Just a random piece of unused pipe or is there water discharge from it?
A930Rocket 08-01-2023 05:51 AM
Can we get a picture from for the back for perspective?
A few questions I have are:
Is the block core filled?
What’s on the other side of the block, garage space or is a backfilled?
How much weight is on it? 1, 2 stories? Just a roof?
It looks like it’s not only settling down. It’s moving out.
Arizona_928 08-01-2023 06:24 AM
Random piece of trash conduit
flatbutt 08-01-2023 06:29 AM
I'm no builder so.... is that a pillow block in the corner? It doesn't look like a corner cinder block that would have had the core containing mortar. Or did the corner block crack?
edit nvr mind I can see the full block from the other angle.
Arizona_928 08-01-2023 06:29 AM
I won't be back there until this weekend. But i can.
Not too much weight. It's a single story 1 car garage.
Not sure about core filled.
Other side is garage space.
I'm thinking it's due to a new roof with a lack of gutters...
911 Rod 08-01-2023 06:54 AM
I'd dig down, remove the blocks and replace.
That is assuming there is foundation to put the new blocks on.
Scott Douglas 08-01-2023 09:01 AM
Did the upper portion move or the lower?
Kind of hard to tell from the pics.
How far up the wall does the zig zag crack go behind the plant?
Seeing this from the inside would help I would think.
Arizona_928 08-01-2023 09:18 AM
From the inside you can see just these blocks pushed out. So it seems like the lower corner moved out and everything else is good.
http://forums.pelicanparts.com/uploa...1690906648.jpg
I can get more pictures this weekend.
Scott Douglas 08-01-2023 09:31 AM
Do you know if the 'floor' of the garage is cracked at the interface of those blocks in the corner?
Scott Douglas 08-01-2023 09:39 AM
I'm finding it interesting that the 'mortar' between the blocks doesn't look like it adhered to the upper blocks at all in the circled area.
Could a car possibly bumped the wall from inside?
Just trying to get to the root cause.
Bill Douglas 08-01-2023 11:58 AM
I think the floor has sunk. seems odd as it's probably a concrete slab.
If the slab has sunk, or broken and sunk, there is some expanding foam that is put under concrete to lift it. Sorry, no idea what it's called but I've been fascinated by the ad' on TV where foot paths, concrete floors etc are levelled.
A930Rocket 08-01-2023 12:55 PM
I’m no engineer, but think a couple options are to lift the block up by lifting the footer up, assuming it has a footer.
Used the existing footer, replace the block as needed, and core fill the cells with a grout mix.
Any way to find out if this is something that happened over time or something bumped it from the inside, as mentioned?
Once you repair it, you can get small plastic gauges that adhere to either side of the crack and it measures the gap over time.
Scott Douglas 08-01-2023 01:45 PM
I'd like to know how the wall moved as shown with the red arrow pointing to the right.
And, how did the lower portion of the wall move without causing a fracture along the red rectangle line?
http://forums.pelicanparts.com/uploa...1690922639.jpg
Zeke 08-01-2023 03:39 PM
No one has asked if there is fill behind this wall. Kinda changes the approach if this is a foundation wall with the garage on top.
Scott, the mortar on blocks is not all that structural laterally. Lateral reinforcement is what rebar and grouting is for. Apparently that corner is light on rebar.
Arizona_928 08-01-2023 04:02 PM
It's a small garage. So it's completely possible to be pushed from the inside. The current tenant has the back filled with stuff.
A930Rocket 08-01-2023 07:04 PM
I did 🙋🏽
…..What’s on the other side of the block, garage space or is a backfilled…..
In addition to grout and rebar, I don’t see any ladder wire.
Arizona_928 08-05-2023 11:32 AM
Tenent had a suv in the garage. The agent ended up just sending these pictures. Back of the garage is flush.
http://forums.pelicanparts.com/uploa...1691260090.jpg
ltusler 08-05-2023 11:41 AM
See if there is a basement repair company in your area that will jack it back in place support it, install rebar in the block voids then pump in very wet concrete. Just had this done at out lake place. the lakeside wall had 1.5" of deflection.http://forums.pelicanparts.com/uploa...1691260699.jpg
Arizona_928 08-05-2023 12:11 PM
That looks exciting.
Did they not put a sealer on the outside?
A930Rocket 08-05-2023 01:12 PM
You don’t want very wet concrete, as that will weaken the psi mixture. After the footer is raised, talk to a concrete company or somebody that pumps concrete with a 2 inch line about what specific grout mix to use.
ltusler 08-06-2023 09:18 AM
Yes, its sealed, drain tiled and a dimpled membrane.
Yes they pumped it in with a 2" hose.
Arizona_928 08-08-2023 06:31 AM
Thanks for the help Rod, Rocket, Scott, Bill and Zeke!
Do you have any more pictures of the process? I find that very interesting for some reason.
