Steering Rack Rebuild?
My E46 needs a steering rack rebuild. The ZHP came with a unique tune to the steering that I want to keep. New racks are NLA.
Rack Doctor used to be the go to but he’s no longer a reliable option. Anyone have a trusted source that rebuilds? Sent from my iPhone using Tapatalk |
I don’t know of anyone, and I heard that Rack doctor went AWOL.
I tried to rebuild one and was not successful. First time though, so who knows what I did wrong. Nowadays, you could probably find something on YouTube. |
There is this video but I don’t think it’s something I want to take on for my daily driver. Plus $100 or so for a spare rack, $100 for the rebuild kit plus down time sourcing the bearings, I’m not sure it’s the way to go. https://youtu.be/W9drVXzCOuM Sent from my iPhone using Tapatalk |
Wow, $1100 for a reman rack from Bosch. Owchies .
No left turn un stoned |
There’s a company in Aus that I was considering buying from, significantly less even with shipping. Ever hear of Lucas Power Steering Racks? EDIT: Sorry, for some reason I thought I was quoting Peter from AUS. Sent from my iPhone using Tapatalk Last edited by wilnj; 08-04-2023 at 05:21 AM.. |
Have rebuild two 944 racks using rebuild kits from 944 online...and both continue to perform perfectly and remain leak-free.
Not all that difficult but a bit tedious, with a bit of extra care required for certain aspects, like removing tie-rods from the polished center carrier without marring the carrier, and replacing certain inner seals/O-rings without marring any critical surfaces. And that carrier needs to display a high degree of polish, and be more or less perfectly cylindrical in cross-section, in order to maintain leak-free performance in concert with the O-rings through which it travels. Its not uncommon in an older rack to have this carrier display a bit of surface-rust, which can often be removed and the polish restored...but this must be done in a way which preserves (within tolerance) spec'd diameter and concentricity in order to remain leak-free. Some folks will chuck the carrier into a drill press and spin-polish with very fine grit paper (1000/1500/2000 then fine compound) - but I have not needed to try this. Also, obviously replace all crush-washers, and maybe refresh (flatten/polish) surfaces which will be sealed by new crush washers. And be really careful not to over-torque any banjo bolts! Finally, if a high pressure hose looks distorted, cracked, etc. - replace it! |
Almost Banned Once
I replied to your PM. I'll check with my buddy who lives in Perth, Western Australia and get back to you. He's a car guy so he may know something about them.
- Peter |
Thanks! Sent from my iPhone using Tapatalk |
